1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
88 Burban
Discussion in '4wd Suburban, Blazer and Jimmy' started by Kevro_N_Chevro, Feb 28, 2020.
  1. Kevro_N_Chevro
    Kevro_N_Chevro Member
    31
    19
    Feb 26, 2020
    NorthEast Tacoma
    First Name:
    Kevin Forbes
    Truck Year:
    1988
    Truck Model:
    V10 Suburban
    Engine Size:
    Update: I ordered the barn door rubber from lmc. Disappointed in the fact that it was not notched out for the hinges. So I had to cut it. Then quite a few of the clips did not come close to lining up. The clips where not quite long enough either. It is mostly glued on. I used a brass punch to help get the clips seated.
    Worked on the head liner. Used 1/8” sanded plywood stained classic grey. I am no carpenter. My seems where not great, I would have liked it to turn out a bit better. Overall I’m happy. Used just a standard transition panel for the seams from Lowe’s. I should have taken the time to stain one like the rest of it but it was a after thought. I know should have thought about my seams before. [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Goldie Driver likes this.
  2. Kevro_N_Chevro
    31
    19
    Feb 26, 2020
    NorthEast Tacoma
    First Name:
    Kevin Forbes
    Truck Year:
    1988
    Truck Model:
    V10 Suburban
    Engine Size:
    So I replaced the tie rods and added that correct steering arm. Wasn’t too bad since I went with all new parts. I have learned that amazon has the right parts Oriellys has to order them and then they where wrong. My local performance shop didn’t have them, although I should have been patient and ordered them from them and had to wait a few weeks.[​IMG]
    TubeTruck likes this.
  3. Kevro_N_Chevro
    31
    19
    Feb 26, 2020
    NorthEast Tacoma
    First Name:
    Kevin Forbes
    Truck Year:
    1988
    Truck Model:
    V10 Suburban
    Engine Size:
    Got the wheels back from powder coat, went with Maxxis MT in a 35. Will need to add some steering stabilizers now. [​IMG]
    Derick C. likes this.
  4. Kevro_N_Chevro
    31
    19
    Feb 26, 2020
    NorthEast Tacoma
    First Name:
    Kevin Forbes
    Truck Year:
    1988
    Truck Model:
    V10 Suburban
    Engine Size:
    I am looking for electric window switches. The single style with the center post that runs through the back. Also needing two electric lock switches. LMC seems like the only spot to get them. Anyone have any other suggestions?
  5. Craig 85
    Craig 85 Full Access Member
    2,459
    1,809
    Jan 25, 2017
    Grass Valley, CA
    First Name:
    Craig
    Truck Year:
    Truck Model:
    K30 SRW
    Engine Size:
    454/TH-400/NP205
    Did you swap out the steering arm? I see the bolts are loose.
  6. Kevro_N_Chevro
    31
    19
    Feb 26, 2020
    NorthEast Tacoma
    First Name:
    Kevin Forbes
    Truck Year:
    1988
    Truck Model:
    V10 Suburban
    Engine Size:
    [​IMG]
    Sure did
    Derick C. and Craig 85 like this.
  7. Goldie Driver
    Goldie Driver Full Access Member
    1,484
    1,772
    Mar 19, 2018
    Houston, Texas
    First Name:
    Britt
    Truck Year:
    Truck Model:
    GMC K1500 Suburban
    Engine Size:
    THAT headliner ain't coming down !! :D
  8. TubeTruck
    TubeTruck I like anything fast enough to do something stupid
    942
    1,150
    Sep 4, 2019
    Northern IL
    First Name:
    Denis
    Truck Year:
    1978, 1975
    Truck Model:
    Suburban K10, GMC K15
    Engine Size:
    400ci, 350ci
    Kroil Oil, the best stuff on the planet!
Share This Page
