1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
88 Burban
Discussion in '4wd Suburban, Blazer and Jimmy' started by Kevro_N_Chevro, Feb 28, 2020.
  1. Kevro_N_Chevro
    Kevro_N_Chevro Member
    31
    19
    Feb 26, 2020
    NorthEast Tacoma
    First Name:
    Kevin Forbes
    Truck Year:
    1988
    Truck Model:
    V10 Suburban
    Engine Size:
    So here it is. My vision is to start as a hunting/fishing rig. Although I need this burban to get me 4-6 hour drives into the mountains and back. The window and door seals are shot. So I will start there. After getting it off the ground and checking out the front end I believe the tie rod ends and ball joints have been updated in the last few years. Radiator will need replaced from the look of it. Odd I know but the neck at the return house is really weak. From there it will need tires. I will run 35s. I have a deal on a 50% set will rims so.... that might work for this year. [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
    Derick C. likes this.
  2. Kevro_N_Chevro
    31
    19
    Feb 26, 2020
    NorthEast Tacoma
    First Name:
    Kevin Forbes
    Truck Year:
    1988
    Truck Model:
    V10 Suburban
    Engine Size:
    I have seen the relay window motor kit on LMC. I have been told a person this forum makes them as well. I am in the market for four of them. Although I need to start on the lock switchs right now. It will lock fine but neither of the switches will even make a click to unlock. Going to dig into that today to find a relay or something.
  3. shanegtr
    shanegtr Full Access Member
    212
    152
    Sep 29, 2018
    Perth, Australia
    First Name:
    Shane
    Truck Year:
    1989
    Truck Model:
    R2500 Suburban
    Engine Size:
    defiantly needs some new tyres - looks weird on the little ones now
    Raybo135 likes this.
  4. Kevro_N_Chevro
    31
    19
    Feb 26, 2020
    NorthEast Tacoma
    First Name:
    Kevin Forbes
    Truck Year:
    1988
    Truck Model:
    V10 Suburban
    Engine Size:
    I plan to run 35's, he seller had 37's on it and wanted 2grand more for the rig with them. He gave the option of taking them off and I gladly agreed. The plan is to get it in a bit better shape. Then proceed with tires and wheels. I would like to eventually wrap the rig in a Matte Stone Grey. BTW Thanks for noticing the rig has missed legs day at the gym a time or two
    TubeTruck likes this.
  5. Kevro_N_Chevro
    31
    19
    Feb 26, 2020
    NorthEast Tacoma
    First Name:
    Kevin Forbes
    Truck Year:
    1988
    Truck Model:
    V10 Suburban
    Engine Size:
    Stock oil pressure gauge. I replaced the sensor. The gauge still pegs out. I am going to try to find the gauge and replace it. Has anyone had this issue? I know someone has
  6. Backfoot100
    Backfoot100 Full Access Member
    258
    349
    Aug 18, 2017
    Florida
    First Name:
    Eddie
    Truck Year:
    Truck Model:
    C1500 Suburban
    Engine Size:
    Carbed 350
  7. Big Chip
    Big Chip Full Access Member
    52
    3,578
    4,604
    Oct 19, 2017
    Michigan
    First Name:
    Kevin
    Truck Year:
    Truck Model:
    C35
    Engine Size:
    I have that issue with my oil pressure gauge now. I had a sender that was leaking so I replaced it and now it pegs at the high end. I believe there are 2 different senders and it's pretty common to get the wrong one. I can't help with any part numbers but if anyone knows I'm sure they will post them soon.
    Kevro_N_Chevro likes this.
  8. RoryH19
    RoryH19 Full Access Member
    1,094
    585
    Aug 21, 2015
    First Name:
    Rory
    Truck Year:
    1987, 1982, 1983
    Truck Model:
    R10 Silverado SWB, K5 Silverado Blazer, K5 Silverado Blazer
    Engine Size:
    350 TBI, LS Swap 6.0, 350 carb
    Just recently had this issue on my 87 R10, 350 TBI.
    It would peg out, every now and then have a normal reading.
    Replaced with a standard sender, goes by the oil filter. Part number PS269 from rockauto.
    Only issue is that the cover that went of the factory one doesn't fit. The new one is wider.
  9. Kevro_N_Chevro
    31
    19
    Feb 26, 2020
    NorthEast Tacoma
    First Name:
    Kevin Forbes
    Truck Year:
    1988
    Truck Model:
    V10 Suburban
    Engine Size:
    I do not see anything by the oil filter. On the left side of oil pan(looking up)I have this one[​IMG]
    [​IMG]
  10. RoryH19
    1,094
    585
    Aug 21, 2015
    First Name:
    Rory
    Truck Year:
    1987, 1982, 1983
    Truck Model:
    Engine Size:
    That looks like your knock sensor in the right side.
    Should look like this...
  11. Kevro_N_Chevro
    31
    19
    Feb 26, 2020
    NorthEast Tacoma
    First Name:
    Kevin Forbes
    Truck Year:
    1988
    Truck Model:
    V10 Suburban
    Engine Size:
    Looking for recommendations for weather stripping. Rock auto has the front and rear doors in stock. The barn doors seem to be varied. There looks to be some generic styles, yet some fitted with ends that screw in. My barn doors don’t have enough metal left at those bottom end to screw anything to. What have other’s used
  12. Kevro_N_Chevro
    31
    19
    Feb 26, 2020
    NorthEast Tacoma
    First Name:
    Kevin Forbes
    Truck Year:
    1988
    Truck Model:
    V10 Suburban
    Engine Size:
    LMC does not sell the barn door style weatherstripping, I have been searching every website I can for it. Any recommendations!!!! Before I go with a generic style
  13. TubeTruck
    TubeTruck I like anything fast enough to do something stupid
    942
    1,150
    Sep 4, 2019
    Northern IL
    First Name:
    Denis
    Truck Year:
    1978, 1975
    Truck Model:
    Suburban K10, GMC K15
    Engine Size:
    400ci, 350ci
  14. Kevro_N_Chevro
    31
    19
    Feb 26, 2020
    NorthEast Tacoma
    First Name:
    Kevin Forbes
    Truck Year:
    1988
    Truck Model:
    V10 Suburban
    Engine Size:
    Thank you! I sent a email to them last Tuesday. Stating that all I could find was the tailgate option. Their response was a apology that they stopped carrying it. I will see at checkout if they are still in stock. Thanks again.
  15. Holl
    Holl Junior Member
    13
    Jul 6, 2017
    First Name:
    Rich
    Truck Year:
    Truck Model:
    suburban
    Engine Size:
    try Steele Rubber. IIRC they were more expensive, BUT they were damn near OEM quality. Id use them again.
Share This Page
