1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
'86 K20 6.5TD Mild Resto
Discussion in '4wd Pick-Ups K/V 20 2500 K/V 30 3500' started by fmxr47, Aug 25, 2017.
  1. fmxr47
    fmxr47 Full Access Member
    438
    316
    Jan 20, 2016
    US
    First Name:
    Justin
    Truck Year:
    Truck Model:
    Engine Size:
    6.5
    Hello, My name is Justin and I like square bodies...
    Now that I have that out of the way. I have some replacement panel issues I could use some help with. My cab corners on both sides line up great on the back panel but are 1/4" off in the door jam you will see in the pictures I post. My second issue is the rocker panels were about gone and I'd like to know what a good measurement is from the lip for the weather stripping from the top to bottom of the door opening so I can make sure my doors will close and half ass line up. I'm not going for a show truck just presentable.
    The truck is an 86 Silverado K20 with a Mechanical 6.5td swapped in, was originally a 6.2
    [​IMG][​IMG][​IMG][​IMG]
  2. gmachinz
    gmachinz Full Access Member
    627
    183
    Nov 10, 2012
    Iowa
    First Name:
    Jabin
    Truck Year:
    Truck Model:
    Engine Size:
    Hows the inner rocker? I strongly suggest hanging your door and tacking the outer rocker to the inner in a few spots, then using the door as an alignment tool to gauge how accurate the outer rocker placement is. I would have completely aligned the rocker to the door before getting serious on the cab corner.
  3. Honky Kong jr
    Honky Kong jr Super Sarcastic Man
    47
    14,890
    9,304
    Jun 14, 2016
    Denver,PA
    First Name:
    J-me
    Truck Year:
    87
    Truck Model:
    Engine Size:
    Lil BB 407
    Should of left the factory door sill for the cab corner. They all kinda suck like that. The rocker gotta go on first. Put your door on and tech screw the rocker on to fit the door. If you still have the piece you cut out of the upright sill I'd weld it back in and cut the corner to fit.
  4. fmxr47
    438
    316
    Jan 20, 2016
    US
    First Name:
    Justin
    Truck Year:
    Truck Model:
    Engine Size:
    6.5
    The rocker is layered inside the cab corner though and the corners were completely gone which is why I'm using the entire replacement panel instead of just a patch in the cancerous spots, my rockers were literally hanging on for dear life by the weather stripping and the inners are gone also, I am doing this as well, need the outer to line up good first then I know where to trim the inner away at
    Shorty81 likes this.
  5. Honky Kong jr
    47
    14,890
    9,304
    Jun 14, 2016
    Denver,PA
    First Name:
    J-me
    Truck Year:
    87
    Truck Model:
    Engine Size:
    Lil BB 407
    Like was stated above use the door to align the rocker. When I did mine, the cab corners I just reshaped it to fit.
    Jrgunn5150 and fmxr47 like this.
  6. fmxr47
    438
    316
    Jan 20, 2016
    US
    First Name:
    Justin
    Truck Year:
    Truck Model:
    Engine Size:
    6.5
    I haven't welded anything up yet but I did put the door on and after some more research I realized I'm ditching the inner rockers and getting some of the outer floor pieces today at summit when I pickup some inner fenders. Everything should make more sense when I see a complete panel that fits the entire gap instead of a patch panel that doesn't even look right, I got the gap looking fairly decent although both rockers have a bow in the middle which I hope to straighten out.
    I appreciate the advice guys, Thank you
    I'll try and post some progress if I get anywhere with it today
  7. fmxr47
    438
    316
    Jan 20, 2016
    US
    First Name:
    Justin
    Truck Year:
    Truck Model:
    Engine Size:
    6.5
    I got the passenger side inner and outer rocker done today and started to mess with the cab corner, it's going to be rough because when I lines up at the top on the back panel it's sticking out from the rocker about 1/2"[​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
    I also think I found the color I'm going with when I ran out to summit today
    [​IMG]
    henrym and JAngeli like this.
  8. Honky Kong jr
    47
    14,890
    9,304
    Jun 14, 2016
    Denver,PA
    First Name:
    J-me
    Truck Year:
    87
    Truck Model:
    Engine Size:
    Lil BB 407
    Looks good you may have to reshape the cab corner..I did
    fmxr47 likes this.
  9. fmxr47
    438
    316
    Jan 20, 2016
    US
    First Name:
    Justin
    Truck Year:
    Truck Model:
    Engine Size:
    6.5
    Yeah I think I'll be cutting some reliefs in it to get the curve I need and then making a new flange around the door jam by trimming it bad and curving it back around. Tek screws will be a big help for that
  10. Honky Kong jr
    47
    14,890
    9,304
    Jun 14, 2016
    Denver,PA
    First Name:
    J-me
    Truck Year:
    87
    Truck Model:
    Engine Size:
    Lil BB 407
    Yup
  11. roadwolf
    roadwolf Full Access Member
    134
    12
    Sep 6, 2011
    France
    First Name:
    Rodolphe
    Truck Year:
    Truck Model:
    silverado 10
    Engine Size:
    5.0
    Hi,
    I am doing nearly the same work here is my result in cm, my rocker panel is well parallel with bottom of the door DSCF4731.JPG
    i have nearly the same with the rear cab corner part the left side is to long as if it has pressed over the original part, i 'll allign the rear and remake the front corner that come over the rocker
  12. fmxr47
    438
    316
    Jan 20, 2016
    US
    First Name:
    Justin
    Truck Year:
    Truck Model:
    Engine Size:
    6.5
    For some reason I cannot see your pictures and have this problem in many other threads also
  13. Honky Kong jr
    47
    14,890
    9,304
    Jun 14, 2016
    Denver,PA
    First Name:
    J-me
    Truck Year:
    87
    Truck Model:
    Engine Size:
    Lil BB 407
    Its tapatalk. That's why you can't see them.
    B.K. Cunningham likes this.
  14. fmxr47
    438
    316
    Jan 20, 2016
    US
    First Name:
    Justin
    Truck Year:
    Truck Model:
    Engine Size:
    6.5
    Oh it's the app itself? Am I better off using the browser to view?
  15. Honky Kong jr
    47
    14,890
    9,304
    Jun 14, 2016
    Denver,PA
    First Name:
    J-me
    Truck Year:
    87
    Truck Model:
    Engine Size:
    Lil BB 407
    Yes. I use my phone only no app tho. After the upgrade to the site tapatalk users are having issues seeing pics.
    fmxr47 likes this.
Share This Page
