86 C10 454 SWAP
lsx95obs
Ca
Adrian
So im swapping my square body with a brand new 454 running hei system only problem Ive ran into is that the truck has no spark it cranks but nothing. Everything on the truck is new! Even tested for 12v at distributor and everything seems to check out. also tried out a different distributor! Any suggestions!?
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
Check for spark at plug and make sure fuel pump is priming and got fuel pressure. That's where I'd start.
how are you checking for spark? If the distributor is properly installed and you are trying to fire it for the first time, do you have a timing light on it? Pics of your setup?
MrHorsepowerLSx
New Jersey
Jeffrey
K35
Does your 12v power source leave the distributor while cranking? Remember it needs to be constant 12v until you turn the key off
1973c10
Don
Welcome :boti:
Jawzjeep
Honk if parts fall off
Washington
Joshua
Suburban
Welcome from Washington.
I'll be keeping an eye on this because the swap is in my future too.
Babs
Ottawa Valley
Chevrolet CUCV
:welcome:
Alaska 79 K-10
Fairbanks Alaska
Bryan
K-10
Flow chart. 12V constant at distributor (while cranking too), hot wire plugged into + battery terminal, coil grounded, coil carbon button installed, control module plugged in at both ends. Best wishes
chrisd9997
