1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
85HeavyChevy's '85 C20 Build
Discussion in '2wd Pick-Ups C/R 20 2500 C/R 30 3500' started by 85HeavyChevy, Jan 3, 2013.
  1. 83swb
    83swb Full Access Member
    314
    Sep 21, 2012
    CT
    First Name:
    Hunter
    Truck Year:
    83'
    Truck Model:
    Engine Size:
    350/th350
    I wouldn't be looking at a new motor until you get all that smog shit off and put that intake and carb on there. Any problems with the current motor?
  2. 85HeavyChevy
    85HeavyChevy Full Access Member
    27
    77
    Jan 3, 2013
    Cherokee, NC
    First Name:
    AJ
    Truck Year:
    Truck Model:
    Engine Size:
    Just a thought. I'm gonna rip the smog off and put the intake and carb on and go from there:superhack::D.
  3. 85HeavyChevy
    27
    77
    Jan 3, 2013
    Cherokee, NC
    First Name:
    AJ
    Truck Year:
    Truck Model:
    Engine Size:
    Got me some Goodies coming in the mail:D:
    Got me a carb renew kit for the truck avenger:
    And a stand to work on:
    The friend I bought it from said it had a bad power valve so I decided to just try and find a rebuild kit. After I get it redone it'll be time to do some :superhack: and:weld: on some "pumps":secret:.
  4. HotRodPC
    HotRodPC Administrator Staff Member
    46,071
    6,571
    First Name:
    Truck Year:
    85 K20 LWB / 86 K5
    Truck Model:
    Silverado / Silverado
    Engine Size:
    454 - Turbo 400 - 3.73 350 - 700R4 - 4.10
    Yeah, most Holley's do have a bad power valve in them. :rofl: 1 backfire thru the intake is all it takes many times.
    Did you get an Ethanol compatible kit? I'm seeing that is the thing to do these days. When you buy your carb kits, make sure you're getting one that says it's ethanal safe or compatible.
  5. 85HeavyChevy
    27
    77
    Jan 3, 2013
    Cherokee, NC
    First Name:
    AJ
    Truck Year:
    Truck Model:
    Engine Size:
    As far as I know its compatible:waytogo:.
    Well I finally started to take apart the carb. Replaced the bad power valve and we stopped to get a can of Carb cleaner. seems straight forward but the gaskets were tight as hell to take off. heres the progress:superhack::
    Coming along good:headbang:
  6. 85HeavyChevy
    27
    77
    Jan 3, 2013
    Cherokee, NC
    First Name:
    AJ
    Truck Year:
    Truck Model:
    Engine Size:
    Well just letting people know I'm still around and kicking:buttkick:. Not much has changed on Blue. The carb is sitting in my room and so is the intake:rolleyes:. Between schooling and helping my dad I hadn't had much time to tinker with 'er. Hopefully before winter me and my dad will get my rear brakes fixed to I can drive 'er for a little while before winter:driver:.
    :Bye:
  7. HotRodPC
    46,071
    6,571
    First Name:
    Truck Year:
    85 K20 LWB / 86 K5
    Truck Model:
    Engine Size:
    Thanks for the update. Sure is a nice truck to have sit during the Summer and Fall. Back brakes isn't but a 20 minute job per side once you got the parts. They're cheap enough, plan on putting in new wheel cylinders too if it's not been done in many years. Just do it while you're there. About $9 each side. Should be able to get all you need and the drums turned for well under $60 doing it yourself.
  8. 85HeavyChevy
    27
    77
    Jan 3, 2013
    Cherokee, NC
    First Name:
    AJ
    Truck Year:
    Truck Model:
    Engine Size:
    That was fast:headbang:. Thanks for the info. I know it's the wheel cylinders that are leaking fluid. The hard part I'm having is there are 2 diffrent sizes for the back brakes and I don't know which I have:think:. I have been driving 'er at least twice a week with a mushy brake pedal but she's still safe:burnout:. I can't get over the heads I turn when she's going down the road:boti:. I also decided if and when I'm gonna paint 'er she's getting just a white top:favorites37:.
  9. 89Suburban
    89Suburban Full Access Member
    47
    23,096
    1,717
    First Name:
    Truck Year:
    Truck Model:
    Engine Size:
    Great pics
    Posted From Hell
  10. Green79Scottsdale
    Green79Scottsdale Full Access Member
    1,966
    2,097
    Aug 8, 2010
    G.R. - MI
    First Name:
    Bob
    Truck Year:
    Truck Model:
    Engine Size:
    Look at your RPO list for the brake package you have. Not sure about your later trucks, but my '79 was only available with two different rear brake set-ups. Shouldn't be that hard at all to get the correct cylinders.
  11. HotRodPC
    46,071
    6,571
    First Name:
    Truck Year:
    85 K20 LWB / 86 K5
    Truck Model:
    Engine Size:
    Prolly 3 in the 85 model. You could get the 14 bolt semi float, or 14b Full Float rear axle, and there are 2 different sizes for the 14b and I think one for the 14b or maybe 2 but 1 of those will interchange with the 14b FF.
  12. 85HeavyChevy
    27
    77
    Jan 3, 2013
    Cherokee, NC
    First Name:
    AJ
    Truck Year:
    Truck Model:
    Engine Size:
    Thanks for all the input. Took some pics but I don't know if there helpful:shrug:. All I know my truck has alot of options:winner_first_h4h::
    Figure I'd let the people who know more than me ponder on it. I see it says rear axle-4.10 rat. Again thanks for all the help:pepper:.
  13. HotRodPC
    46,071
    6,571
    First Name:
    Truck Year:
    85 K20 LWB / 86 K5
    Truck Model:
    Engine Size:
    Alot of Options??? NOT. This is my C20 RPO sticker.
  14. MrMarty51
    MrMarty51 Full Access Member
    69
    5,255
    3,892
    Oct 25, 2012
    Eastern Montana
    First Name:
    Martin
    Truck Year:
    Truck Model:
    Engine Size:
    I just got done with a Holly 650, them gaskets have a finish that reacts to gasoline and makes them gaskets stick tighter~N~crap, I had a heck of a time prying them things apart.
    I thinking they did this in case screws loosened up and they still will not leak.
  15. Green79Scottsdale
    1,966
    2,097
    Aug 8, 2010
    G.R. - MI
    First Name:
    Bob
    Truck Year:
    Truck Model:
    Engine Size:
Share This Page
