Joshua Keith
- Aug 28, 2019
- Memphis
- Joshua
- K10
Hello all!
I have an 85 K10 crate 350 engine that’s running hot. The truck is running around 220 at both idle and highway speeds. Thermostat is new, fluid is full and has a stock radiator. There are 2 issues I see.
1. It has a 3 inch body lift raising the radiator and shroud above the level of the fan.
2. It has a flex fan and no clutch.
Can anyone point me in a direction of a good clutch/fan setup? I see 5 blade fans withy the oddly spaced blades or could I go with an evenly spaced 6 blade? Any 2¢ about the subject would be greatly appreciated! Thank you!
