1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
82 wide side wonder
Discussion in '2wd Pick-Ups C10 C1500 R10 R1500' started by yevgenievich, Apr 4, 2019.
  1. yevgenievich
    yevgenievich Full Access Member
    3,923
    1,494
    Mar 1, 2014
    First Name:
    Viktor
    Truck Year:
    1991
    Truck Model:
    V2500 burb
    Engine Size:
    It is somewhat mine now, except for never finished auction paperwork from six years ago.
    Needs a bit of everything, and I am not even sure if it runs and drives. Just got dumped off the trailer with gasoline can under the hood, no battery and disconnected drive shaft. It has been swapped to a 12 bolt rear and apparently needs an adapter ujoint. Came with 4.8/5.3+4l60e in the bed. I was supposed to pay a bit of extra for the ls motor but everything seemed to be worse.
    MrMarty51 and animal like this.
  2. yevgenievich
    3,923
    1,494
    Mar 1, 2014
    First Name:
    Viktor
    Truck Year:
    1991
    Truck Model:
    V2500 burb
    Engine Size:
    78C10BigTen and MrMarty51 like this.
  3. DoubleDingo
    DoubleDingo Summer Is Near, Hot Temps Are Already Here
    4,487
    2,758
    Jul 3, 2012
    A few hundred feet above sea level
    First Name:
    Shane
    Truck Year:
    1981, 1965
    Truck Model:
    Engine Size:
    Looks sound body-wise.
  4. 1973c10
    1973c10 Full Access Member
    3,370
    6,906
    Sep 25, 2015
    First Name:
    Don
    Truck Year:
    Truck Model:
    Engine Size:
    Looks like a good project
  5. yevgenievich
    3,923
    1,494
    Mar 1, 2014
    First Name:
    Viktor
    Truck Year:
    1991
    Truck Model:
    V2500 burb
    Engine Size:
    Getting the driveshaft figured out. Apparently the truck might have actually came originally with th400, so it had a rear end with 3r ujoints. PO put in a 12 bolt that used 1310 ujoints. Therefore I am waiting for a special conversion ujoint to come in from summit. I have no idea if this 12 bolt was set up with shims or crush sleeve and figured that it is better to leave the yoke in it alone instead of trying to install a 3r pinion yoke that came with the truck.
    MrMarty51 likes this.
  6. yevgenievich
    3,923
    1,494
    Mar 1, 2014
    First Name:
    Viktor
    Truck Year:
    1991
    Truck Model:
    V2500 burb
    Engine Size:
    Drive shaft is a bit too short. About an 1.5". Wondering if a flip kit in the rear would make the drive shaft work.
  7. lownuff
    lownuff Member
    36
    16
    Apr 4, 2019
    AZ
    First Name:
    Alex
    Truck Year:
    Truck Model:
    Engine Size:
    It'll probably push it in a little, but I don't know if it'll be enough.
  8. yevgenievich
    3,923
    1,494
    Mar 1, 2014
    First Name:
    Viktor
    Truck Year:
    1991
    Truck Model:
    V2500 burb
    Engine Size:
    Might be out as a trade for 81 camaro.
    Resized_20150624_120017(1).jpg Resized_20150624_115859(1).jpg Resized_20150624_120025(1).jpg
    MrMarty51 and Old77 like this.
  9. yevgenievich
    3,923
    1,494
    Mar 1, 2014
    First Name:
    Viktor
    Truck Year:
    1991
    Truck Model:
    V2500 burb
    Engine Size:
    About to have a longer driveshaft for it.
    TubeTruck and MrMarty51 like this.
  10. yevgenievich
    3,923
    1,494
    Mar 1, 2014
    First Name:
    Viktor
    Truck Year:
    1991
    Truck Model:
    V2500 burb
    Engine Size:
    Driveshaft is in, and got it running enough to move off the street.
  11. yevgenievich
    3,923
    1,494
    Mar 1, 2014
    First Name:
    Viktor
    Truck Year:
    1991
    Truck Model:
    V2500 burb
    Engine Size:
    Cleaned the calipers and their bleed screws, bled the master and found lines for the rear. Need new hoses for the front. Also found a nice outer tie rod end. Motor has 993 smog heads. And the block has a number stamped that means something. Looks like might be late 80's gm crate motor made in Mexico
  12. HotRodPC
    HotRodPC Administrator Staff Member
    45,267
    5,423
    First Name:
    Truck Year:
    85 K20 LWB / 86 K5
    Truck Model:
    Silverado / Silverado
    Engine Size:
    454 - Turbo 400 - 3.73 350 - 700R4 - 4.10
    Someone hit something pretty hard to tear that tie rod up like that.
  13. yevgenievich
    3,923
    1,494
    Mar 1, 2014
    First Name:
    Viktor
    Truck Year:
    1991
    Truck Model:
    V2500 burb
    Engine Size:
  14. yevgenievich
    3,923
    1,494
    Mar 1, 2014
    First Name:
    Viktor
    Truck Year:
    1991
    Truck Model:
    V2500 burb
    Engine Size:
    Has brakes and shocks. Ready to drive as far as 2 gallons of fuel under the hood will let it.
    MrMarty51 and DoubleDingo like this.
  15. yevgenievich
    3,923
    1,494
    Mar 1, 2014
    First Name:
    Viktor
    Truck Year:
    1991
    Truck Model:
    V2500 burb
    Engine Size:
    Tires were 12 or more years old. Picked up a set of four from discount tire for $230. Cheapest of the cheapest, but they are new and do more than just hold air.
Share This Page
