Some wire ID info for the pro dash:
Truck instrument cluster wiring by circuit id:
39F Pink/Black = Ignition hot (To Pin 25)
150B Black = Ground (To Pin 1)
Sub harness cir.
30A Pink = Fuel Gauge (To Pin 21)
14B Lt Blue = Turn Signal (LEFT) (To Pin 32)
15B Dark Blue = Turn Signal (RIGHT) (To Pin 31)
11B Lt Green = High Beam Light (To Pin 30)
33C Tan/White = Park brake warning (To Pin 15)
I have yet to find out why certain circuits have been DIY rewired on this truck, like the high beam indicator is the single gray/white wire deal hanging down, and the wiper washer is some funky custom setup, oh and the aftermarket cruise control hack job, so cleanup work is in progress.
For the indicator circuits will just make a 6 pin metri-pack or a deutsche sub connector off the truck harness to mate to the dash harness since I could not find a 3D design to make an adapter out of. If anyone knows of one let me know.
The original cluster was a struggle to get out without cracking any of the housing. She's pretty crispy from 40+ California summers. Time to retire it!
I think the fuel gauge has been dicey for a while, I checked the sender ohms and it reads 24 ohms, which should be about 3/4 tank for a 0-90 ohm sender but it always reads 1/4 tank'ish sometimes goes to half. But never full - unless I ground it out.
Got the AC ducting back in place and the new LMC climate control unit installed.
