1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
'78 C20 Suburban
Discussion in '2wd Suburban, Blazer and Jimmy' started by bucket, Feb 22, 2018.
  1. idahovette
    idahovette Full Access Member
    70
    1,379
    1,381
    Aug 7, 2016
    Weiser Idaho
    First Name:
    Perry
    Truck Year:
    1975-1979
    Truck Model:
    K20-K10
    Engine Size:
    You need more shelf space, Viktor!!
  2. bucket
    bucket Super Moderator Staff Member
    38
    20,230
    5,261
    First Name:
    Truck Year:
    Truck Model:
    Engine Size:
    My rigged choke kinda works. It starts right up but the choke pulls open too fast and it dies. So it takes a little bit of throttle action to keep it running at first. When the throttle is let off, it may or may not die. But if it does die, it's just a matter of pumping the throttle to reset the high idle and then restarting the engine. It'll do for now.
  3. MisterB
    MisterB Full Access Member
    351
    295
    Sep 9, 2019
    Northwest
    First Name:
    AJ
    Truck Year:
    Truck Model:
    GMC K2500 4X4
    Engine Size:
    As inexpensive of a wear item a fuel filter is, I'd replace it with a new one, and then run a tank full of a good gas additive like Lucas and see how it runs
    Sent from my SM-N975U1 using Tapatalk
  4. bucket
    38
    20,230
    5,261
    First Name:
    Truck Year:
    Truck Model:
    Engine Size:
    The offending fuel filter has been pitched, there's now a Jegs canister filter with a replaceable filter cartridge. I actually tried a bottle of Lucas somewhere in Tennessee I think it was. It's seen several tanks of fuel since then.
    The replacement Holley carb I tried to run had 2 brand new filters in it.
    MisterB likes this.
Share This Page
