AlexC20
- Aug 9, 2018
- Eugene
- Alex
- C20
- 350 cu in.
Hey everyone, new to the forum. Ive had my 78 c20 for about a month now. It has a year correct chevy 350, 346250 Intake manifold, and 17058213 Q-jet. Long story short- Truck wasnt running well after doing some work to it. Rebuilt the carb, didn't work. Put another carb that I rebuilt on and it still wont work. The vacuum advance port has constant manifold vacuum, with a vacuum gauge hooked up the needle bounces back and forth between 13"-15" of vacuum. The only was to get a stabilized reading at 20" is if I just barely cup my hands around the primary choke butterfly. The mixture screws have no effect what so ever and the idle wont go any lower then 1200-1000 rpms. This sounds like a obvious vacuum leak but I'm not figuring out where. We eliminated everything on the outside of the carb :brake booster and check valve, all vacuum lines and they're respective spots to be hooked up to, and intake manifold. I've tried different insulator gaskets hoping it would work but it didn't. Why would the carb only pull the correct vacuum with my hand over the choke blade and why do the mixture screws have no effect? I've tried looking for leaks on the outside of carb as well and cannot find any. Also one last detail. When putting your finger over the vent tube I can feel just a small amount of vacuum, this was also confirmed by my father and uncle.
