1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
73 K10 SWB frame off redo
Discussion in '4wd Pick-Ups K10 K1500 V10 V1500' started by hoagster, Sep 9, 2018.
  1. hoagster
    hoagster Supporting Member Supporting Member
    470
    795
    May 16, 2017
    California
    First Name:
    Truck Year:
    1973, 1994
    Truck Model:
    K10, 2500 suburban
    Engine Size:
    5.3l, 7.4l
    So I have been working on this for sometime now, but the thread was in the intro. So I will be posting lots of pictures to get everything up to date. Betsy.jpg
  2. hoagster
    470
    795
    May 16, 2017
    California
    First Name:
    Truck Year:
    1973, 1994
    Truck Model:
    K10, 2500 suburban
    Engine Size:
    5.3l, 7.4l
    This is a one family truck that my dad gave me when I retired from the Air force. My son is helping and it will be his truck in the future. So she has been torn down, and we are at the clean up/repair stage!
    FireTruck1984 likes this.
  3. hoagster
    470
    795
    May 16, 2017
    California
    First Name:
    Truck Year:
    1973, 1994
    Truck Model:
    K10, 2500 suburban
    Engine Size:
    5.3l, 7.4l
    so far we haven't had any issues with removing anything. A couple of area's of rust passenger side front clip, tub will need to be replaced. Rocker on the same side needs some attention. 068.jpg
    FireTruck1984, ajd89 and Snoots like this.
  4. hoagster
    470
    795
    May 16, 2017
    California
    First Name:
    Truck Year:
    1973, 1994
    Truck Model:
    K10, 2500 suburban
    Engine Size:
    5.3l, 7.4l
    few more things to remove before the sand blasting frame prep. So this is were we are at so far will keep you posted. I did fid the engine for her so here's a sneak peak
  5. hoagster
    470
    795
    May 16, 2017
    California
    First Name:
    Truck Year:
    1973, 1994
    Truck Model:
    K10, 2500 suburban
    Engine Size:
    5.3l, 7.4l
    So I have a long ways to go before I here that run , but it will be worth it!
  6. hoagster
    470
    795
    May 16, 2017
    California
    First Name:
    Truck Year:
    1973, 1994
    Truck Model:
    K10, 2500 suburban
    Engine Size:
    5.3l, 7.4l
    I will have a lot of left over parts, engine wise if anyone is looking for something let me know! This is what the engine looks now! But I have everything that goes with it.
    Craig Nedrow and FireTruck1984 like this.
  7. Camar068
    Camar068 Supporting Member Supporting Member
    2,713
    1,025
    Feb 5, 2014
    Kentucky
    First Name:
    Truck Year:
    Truck Model:
    Engine Size:
    10 yrs Air Force
    good job. You can spray those exhaust manifolds with Ospho (after cleaning with a brush) and let them sit overnight. Then spray them with Rust-o-leum Ultra high heat spray paint. I did it to my LS manifolds and they still look as good as they did when I sprayed them. No chipping or anything yet (4 months run time).
    FireTruck1984 and hoagster like this.
  8. Madhorn
    Madhorn Full Access Member
    508
    750
    Jan 16, 2017
    AR-Arkansas
    First Name:
    Ken
    Truck Year:
    Truck Model:
    Engine Size:
    5.3/NV4500/NP205/4:56 gear/35in tires
    Your off to a great start. What trans are going run?
  9. hoagster
    470
    795
    May 16, 2017
    California
    First Name:
    Truck Year:
    1973, 1994
    Truck Model:
    K10, 2500 suburban
    Engine Size:
    5.3l, 7.4l
    Keeping the sm465/205 combo! live in norcal, Not a lot of highway driving and she's going to be used mostly for cruising to the lake with a bass boat attached.
    akchevrolet and FireTruck1984 like this.
  10. Madhorn
    508
    750
    Jan 16, 2017
    AR-Arkansas
    First Name:
    Ken
    Truck Year:
    Truck Model:
    Engine Size:
    The sm465/205 is what my 77 had in it, great combo. I installed the NV4500 for the overdrive, I intend to drive my truck a lot. One thing you may want to check is the coupler that connects the 465 out put shaft to the 205 input shaft. Mine was worn to the of failing soon. Even the 465 out put shaft was worn to the point of needing to be replaced if I were going to reuse it.
  11. hoagster
    470
    795
    May 16, 2017
    California
    First Name:
    Truck Year:
    1973, 1994
    Truck Model:
    K10, 2500 suburban
    Engine Size:
    5.3l, 7.4l
    Took me a few days to get all the snarf off the trans/diff but they are on the way to get a overhaul.
  12. hoagster
    470
    795
    May 16, 2017
    California
    First Name:
    Truck Year:
    1973, 1994
    Truck Model:
    K10, 2500 suburban
    Engine Size:
    5.3l, 7.4l
    Still cleaning up the frame have a co worker that does powder coating, so front and rear axles are coming off and the frame is slowly getting stripped of rust and paint. found the steering box area cracked so that is going to be repaired also.
  13. hoagster
    470
    795
    May 16, 2017
    California
    First Name:
    Truck Year:
    1973, 1994
    Truck Model:
    K10, 2500 suburban
    Engine Size:
    5.3l, 7.4l
    Tons to do on the frame
  14. hoagster
    470
    795
    May 16, 2017
    California
    First Name:
    Truck Year:
    1973, 1994
    Truck Model:
    K10, 2500 suburban
    Engine Size:
    5.3l, 7.4l
    Still removing parts and prepping the frame for powder coating, and front and rear axle cleanup and repair/rebuild
  15. hoagster
    470
    795
    May 16, 2017
    California
    First Name:
    Truck Year:
    1973, 1994
    Truck Model:
    K10, 2500 suburban
    Engine Size:
    5.3l, 7.4l
    ok question for those paying attention. What color should the sm465/np205 be? Not that this is a restore back to original but both have been rebuilt, resealed and they are stripped ready for paint? Should I just clear coat the Sm465 and factory red the np205? Or just both black to match the frame?
Share This Page
