6.2 rebuild for bad head gasket
NZurban
Blenheim, NZ
Rich
K20 Suburban
6.2L diesel
So after much diagnosing I've finally concluded that head gasket replacement is necessary on my '84 K20 Suburban 6.2 diesel. Does anyone have any advice on doing this procedure? Should I get the cylinders honed while I have it out of the vehicle or should I just replace the head gaskets with the engine still in the vehicle? What about new piston rings? There is a little smoke on start up, especially if it's been sitting for a few days, maybe that's bad glow plugs. I'll also be replacing those while the vehicle is off the road. Any other advice/tips gratefully appreciated.
Rickf
Grafton NH
1974, 1954 & a 1937
How did you conclude it is a head gasket issue, bubbles in the coolant,white exhaust smoke, milky engine oil? You might try a compression and/or leak down test first. If it's low on compression a leak down will tell you if it's a ring or valve issue. How many miles or km are on it?
Dave 84
Arizona, glendale
Dave
X2!
NZurban
Blenheim, NZ
Rich
K20 Suburban
6.2L diesel
It regularly fills the overflow tank on a 20 - 30 mile trip out of town, fine on the open road but overheats as soon we hit urban speeds. Get home and the overflow is always bubbling. Changed the thermostat, got a new slightly less pressure radiator cap, checked the waterpump etc etc Doesn't blow white smoke, no milky engine oil Think it has about 166000 miles on it.
Rickf
Grafton NH
1974, 1954 & a 1937
At 166,00 miles, it's barely broken in. Bubbles in the coolant are most likely from a head gasket or a cracked head. If it has decent oil pressure, I'd just pull the heads. If the head gaskets look ok, have the heads checked for cracks.
NZurban
Blenheim, NZ
Rich
K20 Suburban
6.2L diesel
Any particular brand of headgasket? I looked at some FelPro ones at RockAuto, says they're molded rubber construction, seems unusual.
kmousseau8
