5x5 2 inch spacer ?
Eighty5ov
Canada
Ov
c15
hey guys,
I have a 2wd 1985 gmc c1500 and I got 15x10 wheels on the back with 295’s. I want to put 2 inch wheel spacers on the back but can’t seem to find any. Does anyone have a reliable source? Or any experience in this? Thanks
Chevy 88
Canada
f7t6
GMC
eBay or Amazon.
ali_c20
Austria
Alexander
C20, K5
You want to use adapter style spacers and get them from a company with a good reputation which tests the stuff they produce and not online China junk.
I run Motorsport Tech steel adapter style steel spacers on my K5.
They don't have the 5 lug spacer (steel) in stock but they can produce any spacer to your specs.
Bora aluminum spacers are made by them and they are in stock for 5 lug axles.
https://www.motorsport-tech.com/bora.html
My 0.02$
Huh? You have 15x10s AND want to run a 2" spacer? You WANT the wheels sticking out of the back of the truck? As short and small as the studs are on these drums, ain't no way I'd ever do that
WFO
Texas Panhandle
Plus, it would end up lookin like a roller skate.
Eighty5ov
Canada
Ov
c15
Yeah I want them to stick out a bit with the 295’s. I can’t find a decent set tho
That's cuz there's not alot of demand for them. As I said before, it's more a concern of the rear wheel studs. I'm not anti-spacer, I've run them on several of my '99-07 trucks without issue. The problem is the studs on these squarebody trucks are not long enough or large enough to safely run spacers, especially one of that size. It'll put tremendous stress on the wheel studs and probably break off at some point, it's a safety concern.
If you want to run the spacers, if you find some you like, you really need to pull the axles out and get larger, longer studs installed and have the drums drilled larger to fit over the new studs. That's the only way to do it safely.
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
My 0.02$
^^^^ This
I agree with the posters that say the wheel studs on squarebodies are rather small and 2" will add a lot of stress on them
BUT if you run any spacers get something American made:
Spydertrax
Synergy Mfg.
Never heard of BORA but looks like nice stuff.
legopnuematic
Licensed Junk Dealer
MO
Spencer
What wheels are you running/planning to use?
15x10, but what offset/backspacing?
brooksman9
Olive Branch, MS
Patrick
Silverado & Custom Deluxe
350 & 305
Check with Stephen at Wheel411.com. if anyone knows he does.
86Blueberry454
Kevin
I ran a set of Amazon 2" adapters to go from 5x5 to 5x4.75 for one season. I can confirm it did look sketchy when torqued down on them short studs, but there were no issues. If you go that route, check them periodically.
Scott91370
Burleson, Tx
Scott
Sierra1500
BORA all day - they will custom make any size you need. Them and the Fred Goeske are the only brands I would consider (I run BORA).
that_orange_c10
