454 vapor lock
Smoky1978
Minnesota
Steven
Sierra
So thought I had it figured out but looks like I am still having issues with vapor lock. I am wondering if there was a factor heat shield in this location? Do you think it would help if I made my own and added one there?
Sad Sack
Nebraska
Goober
C15
Are you using ethanol blend gas?
Radiohead
That guy on the Columbia
MCMLXXIX
C-20 Silverado Camper Special
The BBC C20 had a hard fuel line that ran above the frame rail and was of a larger diameter than the 3/8" hardline usually found inside the frame rail. When I did the hardline over, I went back to the inside frame rail configuration like a SBC would use. In hindsight, I'm pretty sure I've screwed the pooch doing it that way, although I've not had a chance to test the theory yet. I plan on long tube headers too, so I think I will need to fab a heat shield for the area from some 16 GA.
In your example, I would try making up a heat shield and see if it helps.
I'm glad I saved that particular piece.
awar
K35
I would move the suction line to the outside of the frame and run it up one the inner fender. My 80 K30 frame has heat shields where the passenger side exhaust ran close to the fuel line where it runs around the transfer case.
Smoky1978
Minnesota
Steven
Sierra
would you have a picture of how that is setup?
awar
K35
doo-daa
