Slooptin
- Mar 6, 2017
- Houston
- Vance
- k30
Ok, I'm re-installing my Q-Jet in my truck and had some questions about vacuum line routing. I'm trying to follow the vac diagram, but it isn't matching how this truck came to me or really making a ton of sense (I'm a carb novice). the PO also disconnected everything from the charcoal canister. With that being said, my questions are:
1. I have the red circled port (port B on diagrams) attached to the primary choke vacuum brake (not installed yet) and to the distributor. Is that correct?
2. Green (port H) and blue (unlabeled) are a mystery to me. where are they supposed to be hooked up if the cannister is off? Port T (above the blue one) was also left open. is that ok?
3. There is a sensor(?) attached to the thermostat housing that looks like it has three vacuum ports on it (second pic). What is it, and is it supposed to be attached to anything?
Thanks in advance for any assistance!
