1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
3+3 - L18/465/203/205/Rockwells
Discussion in '2wd Pick-Ups C/R 20 2500 C/R 30 3500' started by FrostBite, May 9, 2011.
  1. chevyfox
    chevyfox Junior Member
    27
    26
    Aug 22, 2014
    mo
    First Name:
    isaac
    Truck Year:
    Truck Model:
    v10
    Engine Size:
    Sub'd
  2. FrostBite
    FrostBite Full Access Member
    32
    127
    10
    May 9, 2011
    Hazlehurst, Ga
    First Name:
    Truck Year:
    83
    Truck Model:
    Engine Size:
    8.1L
    I've been using a 20 gallon compressor that has been around longer than me to supply my shop air needs and it is starting to get a little long in the tooth. Last month the tank developed a rust induced pinhole, and right after fixing that the line connecting the two cylinders 'sploded and shut down all forward progress on replacing the rocker panels. It's kind of hard to use an air powered die grinder with no air power. Who knew...:doah:
    Rather than keep patching the 'lil fella back together I decided to replace it with a compressor that will outlive me. After snooping around the Internet a bit, I settled on a Quincy 7.5 HP 80 gallon unit, I just need to figure out where I'm going to put it and how I'm going to power it. Anyone have any experience with these?
    Since I can't move forward on the rocker panels, I decided to check out an auction for a machine shop whose owner was retiring in Milledgeville, Georgia, and in my mind, I scored. The important loot is...
    A plethora of bins.
    A new Baldor 14" grinder, which should have no problem making it hard to count to ten should I get careless. ($300 by the way, I'm pretty pleased)
    And the best for last... a 3.375 twist drill! I have no use for this, but couldn't resist the AWESOMENESS.
  3. 89Suburban
    89Suburban Full Access Member
    47
    23,093
    1,712
    First Name:
    Truck Year:
    Truck Model:
    Engine Size:
    Man I wish I could come over and play in your shop. :D
    Thanks for the update
  4. HotRodPC
    HotRodPC Administrator Staff Member
    46,061
    6,558
    First Name:
    Truck Year:
    85 K20 LWB / 86 K5
    Truck Model:
    Silverado / Silverado
    Engine Size:
    454 - Turbo 400 - 3.73 350 - 700R4 - 4.10
    Cool new toys !!!
    Hang that drill boat on the wall over the sofa in the living room !!!
  5. FrostBite
    32
    127
    10
    May 9, 2011
    Hazlehurst, Ga
    First Name:
    Truck Year:
    83
    Truck Model:
    Engine Size:
    8.1L
    I'm running out of room to play. A CCLB in a 19' x 29' shop doesn't leave a lot of wiggle room!
    I told the guy I was going to put it on the mantle.
    I unloaded and tested the grinder today.
    It is a tad large.
  6. Stewzer55
    Stewzer55 Full Access Member
    2,235
    35
    Dec 4, 2013
    Ohio
    First Name:
    Stew
    Truck Year:
    1988
    Truck Model:
    R30
    Engine Size:
    Nice score!
  7. HotRodPC
    46,061
    6,558
    First Name:
    Truck Year:
    85 K20 LWB / 86 K5
    Truck Model:
    Engine Size:
    Damn, so do you have a Phase 3 electrical system in your house or what? Running all that commercial industrial type equipment it might be needed. :happy175:
  8. Diggerdan11
    Diggerdan11 Junior Member
    15
    16
    Aug 22, 2012
    Tigard, OR
    First Name:
    Daniel
    Truck Year:
    77
    Truck Model:
    Engine Size:
    Awesome build! Sub'd
    Great Choice going with the 8.1 that engine is such a beast.
  9. FrostBite
    32
    127
    10
    May 9, 2011
    Hazlehurst, Ga
    First Name:
    Truck Year:
    83
    Truck Model:
    Engine Size:
    8.1L
    Thanks!
    There's a nuclear power plant 8 miles from my shop that I have a direct feed from.:party36: Just kidding, I use a phase converter to generate the 3 phase power.
    (Pay no attention to the wiring, I was testing out the grinder so the wiring was temporary.)
    Thanks! I hope it will be awesome.
  10. FrostBite
    32
    127
    10
    May 9, 2011
    Hazlehurst, Ga
    First Name:
    Truck Year:
    83
    Truck Model:
    Engine Size:
    8.1L
    After sitting on my butt for three months I finally got my new compressor. Now I need a regulator and some pipe to plumb the air over into the main shop.
    My one disappointment is that it has a WEG motor. Apparently Quincy uses both Baldor and WEG and there is no way to request one or the other.
    And yes, that is an oil filter and pressure guage hanging off the front of the pump.
  11. HotRodPC
    46,061
    6,558
    First Name:
    Truck Year:
    85 K20 LWB / 86 K5
    Truck Model:
    Engine Size:
    Still better than one of the AO Smith little motors.
  12. FrostBite
    32
    127
    10
    May 9, 2011
    Hazlehurst, Ga
    First Name:
    Truck Year:
    83
    Truck Model:
    Engine Size:
    8.1L
    The new Super Swamper Work Bench.
    89Suburban likes this.
  13. heffalump
    heffalump Full Access Member
    36
    364
    22
    Jul 16, 2013
    Lafayette ga.
    First Name:
    jeremy
    Truck Year:
    90
    Truck Model:
    2500 suburban
    Engine Size:
    Whatever works... I'm using an old foldout sewing machine for my workbench at the moment. .
  14. foamypirate
    foamypirate Full Access Member
    31
    3,294
    377
    Pflugerville, TX
    First Name:
    Jake (Mr. Wilson)
    Truck Year:
    1988
    Truck Model:
    R20
    Engine Size:
    6.0L LQ9 - NV4500
    Looks like you are doing the same thing I just did! I'm jealous of your pressure lubed Quincy though. I had to "settle" for the lowly QT-54 splash lubed model, but I did get a Baldor motor, so neiner neiner! :D
    I've since finished up my install with brass unions and more support and brackets for the FRL. Post pictures of your install when you are done!
    [​IMG]
  15. 89Suburban
    47
    23,093
    1,712
    First Name:
    Truck Year:
    Truck Model:
    Engine Size:
    Nice
Share This Page
