1987 ‘Vette stainless manifolds. Will they work?
Gander
Army
Dirty Bay, TX
Lawrence
Found them off a 1989 ‘Vette. I can get them for $25. They’ve got AIR tubes but I can cut them off and have them welded up. I’ve never seen these before, they’re like shorty headers with really small tubes and then instead of wrap there’s aluminum heat shields that cover them up. Anyone run these on a pickup? I can’t see why they wouldn’t work and I’m wondering if they’d offer any improvement over stock manifolds?
They don't flow as well as long tubes,they out flow truck manifolds,comparable to 2" Rams horns,but I don't think they'll fit a square. I looked at a pair pretty hard at Pik n Pull but didn't think they'd work on anything I own. That was only by looking though didn't pull them take them home or try them.
Gander
Army
Dirty Bay, TX
Lawrence
My truck is a 4x4, I’ve heard rams horns fit with just a little work on the 4x4 trucks and these look like they exit about where the rams horns would.
I noticed the ports on the headers are round and not square. Looking online I see folks saying it’s not a problem. I may go ahead and get these and see what I could do with them. I could always swap to a modern starter if that’s an issue, them getting too close to the starter.
I pulled the heads off the Vette at Pik n Pull Cheap Aluminum heads small chambers decent flow #s. Like I said I didn't think the manifolds woukd work so I left them. I hope they work for you,please keep us posted. If I were you I'd be interested if I could get the heads cheap. I'm sorry,I just read more thoroughly,mine was for a C10 not a K. Good luck.Still keep us posted.
Moderator
Aluminum 113 heads? They are supposed to be pretty darn good. They were used on the early ZZ crate engines too.
Gander
Army
Dirty Bay, TX
Lawrence
I don’t think the heads would work for me. My truck is a 1987 so 5.7TBI so I don’t think my intake would bolt up to them. The heads and the rest of the motor is long gone anyway, though they did leave these manifolds/shields and I was thinking since I can basically get them for nothing maybe they’d be an improvement over the stock truck manifolds. I know I’m going to need to figure out what to do about the O2 sensor. On the vette there’s a bung welded to the pipe just below where it bolts up to the collector. Might just cut that off and use that. I’m going to get these home if they’re still there today and take a closer look.
I hope they work for you,yep.they should be an improvement. The heads would have worked but doesn't matter now. But so you know in the future the difference in intakes and heads( pre Vortec) is the angle on the center 4 bolts. You egg out the center 4 bolt holes and the manifold will work on early heads,and vice versa.
doo-daa
