BJedi76
- Nov 7, 2019
- Soldotna, Alaska
- B.J.
- GMC Sierra Classic 1500 4x4 SWB
- 305”
1986 GMC 4X4 sierra classic 1500To make a long story short, I ended up with a Frankenstein w/mismatched parts from all sorts of squarebodies.
I am trying to rebuild it, but I I am having trouble deciphering what actual parts I am supposed to be acquiring.
for example; I am currently rebuilding the fuel system. I only have the driver side 16 gallon tank. Not only is there NOT a passenger side tank, but there isn’t even a gas door on that side.
I have: a newly rebuilt M4MC w/Electric choke conversion, new (pump to carb) hard line, & a new (3 line) mechanical fuel pump.
I still need to replace the fuel line going back to the tank and the “tank pick up float assembly”, but I am unsure as to which assembly I should have. I have found;1, 2, and 3 line pick up float assemblies. I simply want the minimum that will work.
Also, We do not have DEQ inspections here in Alaska, so I was wondering if the carbon vapor fuel canister can be bypassed or if it’s necessary.
thank you in advance for any educated advice.
