1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
1982 Chevy G30 Van w/ Pathfinder 4x4 conversion
Discussion in 'G Series GM 3rd Gen 71-95 Vans, Pathfinder' started by Marty, Oct 26, 2020.
  1. Marty
    Marty Full Access Member
    152
    221
    Apr 14, 2018
    California
    First Name:
    Marty
    Truck Year:
    Truck Model:
    G30
    Engine Size:
    I did't have a brass drift and I couldn't find the old lug nuts to thread on to the lugs but being an impatient person and knowing I'd be replacing the lugs anyway, I figured I'd just hit it with a hammer. Didn't hit it very hard but it moved. So, I just went around to the others and they all popped free with little effort.
    Then I stood on the drum and pulled up on the hub and it separated no problem.
    This hub will get the full treatment, new races, bearings, and seal (once the parts arrive). Then I'll mate the hub with the new drum (also, once that arrives).
    Anyone ever use one of these lug installer tools before?
    https://www.amazon.com/gp/product/B000ETUD22/ref=ox_sc_act_title_2?smid=ATVPDKIKX0DER&psc=1
    DoubleDingo likes this.
  2. Marty
    152
    221
    Apr 14, 2018
    California
    First Name:
    Marty
    Truck Year:
    Truck Model:
    G30
    Engine Size:
    Some more vehicle information...
    The sticker says the GVWR = 8600 lbs with GAWR Front = 3900 lbs and GAWR Rear = 5360 lbs. But I thought the GVWR = GAWR Front + GAWR Rear. But here we have GAWR Front + GAWR Rear = 9260 lbs, which is 660 lbs > the stated GVWR. What am I missing?
    And Pathfinder instruction I found on the dog house.
  3. Craig 85
    Craig 85 Full Access Member
    2,986
    2,461
    Jan 25, 2017
    Grass Valley, CA
    First Name:
    Craig
    Truck Year:
    Truck Model:
    K30 SRW
    Engine Size:
    454/TH-400/NP205
    My K30 has a GVW of 9200 due to the fact I have 3.73 gears. 4.10's would have been 10K. My F and R ratings total out at 10584.
    DoubleDingo and Marty like this.
  4. Turbo4whl
    Turbo4whl Supporting Member Supporting Member
    765
    1,221
    Oct 30, 2019
    Downingtown, PA
    First Name:
    Wayne
    Truck Year:
    Truck Model:
    Jimmy
    Engine Size:
    Not uncommon for the GVWR to be less than the two stated axle ratings. This could even be the case because of the factory fitted tires. All 4 tires need to match the rating of the axles or more.
    With the Pathfinder mod and the front axle replaced there should be a rating from them posted as well. That would be required in Pennsylvania. Maybe you did not find the Pathfinder sticker, or it is missing.
    Marty and bucket like this.
  5. Marty
    152
    221
    Apr 14, 2018
    California
    First Name:
    Marty
    Truck Year:
    Truck Model:
    G30
    Engine Size:
    No brake drum yet but the hardware kit and bearing set came in giving me parts enough to play with.
    Before...
    After...
    I'll be dropping off the bearings, races, seal and hub at the local shop shortly. Brake drum should be in next week.
    89Suburban, DoubleDingo and Blue Ox like this.
  6. Marty
    152
    221
    Apr 14, 2018
    California
    First Name:
    Marty
    Truck Year:
    Truck Model:
    G30
    Engine Size:
    Parts came in and had a shop assemble the hub and drum.
    No issues mounting it on the axle spindle.
    And then buttoning up the axle.
  7. Marty
    152
    221
    Apr 14, 2018
    California
    First Name:
    Marty
    Truck Year:
    Truck Model:
    G30
    Engine Size:
    Rebuilt power brake booster also came in this week with a new master cylinder (which will need bench bleeding before install).
  8. Marty
    152
    221
    Apr 14, 2018
    California
    First Name:
    Marty
    Truck Year:
    Truck Model:
    G30
    Engine Size:
    Friend stopped by to lend a hand. Got the power brake booster mounted in position and linked up to the brake pedal.
    78C10BigTen likes this.
  9. Marty
    152
    221
    Apr 14, 2018
    California
    First Name:
    Marty
    Truck Year:
    Truck Model:
    G30
    Engine Size:
    Blew out the rear hard lines first with brake cleaner and then compressed air then attached the hard lines to the rear wheel cylinders on both driver and passenger side.
    And installed a rear braided wire brake hose (Rough Country Part #89335-2.
    Sorry for the poor exposure on this one.
    I will pressure test the system once I've sorted out the front brakes and master cylinder.
  10. Marty
    152
    221
    Apr 14, 2018
    California
    First Name:
    Marty
    Truck Year:
    Truck Model:
    G30
    Engine Size:
    Front brakes... finally! Passenger side caliper came off with no issue. The pads still had friction material on them and there were no grooves worn into the disc.
    Since the calipers are unreliable due to age, I plan to replace them along with the pads. I'm not replacing the discs for now as I want to keep costs down until I get a chance to test on the engine, trans and transfer case. This also means, I'm not going to service the locking hubs which, thankfully, are not frozen. Pretty cool that Pathfinder had their own locking hubs. Hopefully I will be able to keep them in service.
  11. Craig 85
    2,986
    2,461
    Jan 25, 2017
    Grass Valley, CA
    First Name:
    Craig
    Truck Year:
    Truck Model:
    K30 SRW
    Engine Size:
    454/TH-400/NP205
    bucket and Marty like this.
  12. Marty
    152
    221
    Apr 14, 2018
    California
    First Name:
    Marty
    Truck Year:
    Truck Model:
    G30
    Engine Size:
    Front right brake caliper markings. My understanding is that although Pathfinder used a Dana 44 from a Ford for the front axle, the knuckles and brakes were GM. This caliper was cast with "GM" (bottom right of the "R"). Not sure what the other markings mean beyond assuming "R" means "right." I think 18007153 is the casting number.
    DoubleDingo, Shorty81 and 78C10BigTen like this.
  13. Craig 85
    2,986
    2,461
    Jan 25, 2017
    Grass Valley, CA
    First Name:
    Craig
    Truck Year:
    Truck Model:
    K30 SRW
    Engine Size:
    454/TH-400/NP205
    It is the casting number. Here's a list of interchange part numbers. Once on the link, there is an application tab to show what other vehicles ran this caliper.
    https://www.yoyopart.com/oem/11480079/casting-18007153.html#top
  14. 89Suburban
    89Suburban Full Access Member
    47
    22,992
    1,194
    First Name:
    Truck Year:
    Truck Model:
    Engine Size:
    Awesome project and nice work there sir.
    Marty likes this.
  15. Marty
    152
    221
    Apr 14, 2018
    California
    First Name:
    Marty
    Truck Year:
    Truck Model:
    G30
    Engine Size:
    Front brake day! Calipers and pads are in. Napa had everything in stock (parts numbers pictured below).
    As with the rear, I replaced the front lines with Rough Country braided steel lines (Part # 89360S)...
    https://www.amazon.com/gp/product/B0776GB5TC/ref=ppx_yo_dt_b_asin_title_o07_s00?ie=UTF8&psc=1
    The Rough Country brake lines come with this hanger bracket that wasn't needed for my application so I deleted it (probably the longest part of the job).
    Driver and passenger side brake calipers were Part # 2257XA and 2257XB (not sure which part number is right or left). Brake pad set was Part # UP728AM.
    Craig 85, DoubleDingo and Shorty81 like this.
Share This Page
