1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
1981 "Ratchet Strap" C-10
Discussion in '2wd Pick-Ups C10 C1500 R10 R1500' started by ALL-OF-IT, Jul 5, 2019.
  1. ALL-OF-IT
    ALL-OF-IT Member
    40
    31
    Jul 2, 2019
    Nebraska
    First Name:
    Adam
    Truck Year:
    Truck Model:
    Engine Size:
    323.425844 cubic inches
    To keep story telling time short, i fab'd a twin turbo setup for a guys Silverado SS and part of his payment was this 1981 C-10. It was completely torn apart, cab was only sitting on the chassis. Only came with what you see, no engine, no trans, not even hardware was included... So this c10's new shot at life began by being ratchet strapped onto the trailer, ratchet strapped to itself and ratchet strapped to anything to keep it together, or on the trailer at least, for the ride back home.
  2. ALL-OF-IT
    ALL-OF-IT Member
    40
    31
    Jul 2, 2019
    Nebraska
    First Name:
    Adam
    Truck Year:
    Truck Model:
    Engine Size:
    78C10BigTen likes this.
  3. ALL-OF-IT
    ALL-OF-IT Member
    40
    31
    Jul 2, 2019
    Nebraska
    First Name:
    Adam
    Truck Year:
    Truck Model:
    Engine Size:
    Rounded up some hardware out of the good ol bolt bucket. On the way back i had to stop and fill up my jugs with "race gas" for the mustang (e-85)
  4. ALL-OF-IT
    ALL-OF-IT Member
    40
    31
    Jul 2, 2019
    Nebraska
    First Name:
    Adam
    Truck Year:
    Truck Model:
    Engine Size:
    This sunday i am supposed to be picking up the donor. 03 silverado 2wd/5.3 runs and drives for $1000.... Score! Also, ordered a complete mounting kit from LMC, for the rad support, cab and bed. Need to get some ICT Billet LS adapter plates and some sbc clamshell mounting brackets yet. Ill make the trans crossmember and wiring harness. Need to figure out what i want to do for fuel system. Get the air ride ironed out, wired and plumbed. and well, everything else . Ill do my best to update as i go :happy160:
  5. K201979
    K201979 Full Access Member
    850
    792
    Oct 22, 2018
    Winona, missouri
    First Name:
    Hippie
    Truck Year:
    Truck Model:
    Engine Size:
    350ci
    Subscribed:popcorn:
    ALL-OF-IT likes this.
  6. ALL-OF-IT
    ALL-OF-IT Member
    40
    31
    Jul 2, 2019
    Nebraska
    First Name:
    Adam
    Truck Year:
    Truck Model:
    Engine Size:
    Donor I picked up. 2003 Silverado 1500 5.3 flex fuel, 2wd 4l60e. Rusted to 'chit edition. Aka the 'Chitrado. I've never seen rust like this on an 03. Weld seems below doors literally split apart lol its badddddd. Surprisingly tho. Haven't had any problems with removing bolts. It must be the new can of WD-50 I've been using
    K201979 likes this.
  7. ALL-OF-IT
    ALL-OF-IT Member
    40
    31
    Jul 2, 2019
    Nebraska
    First Name:
    Adam
    Truck Year:
    Truck Model:
    Engine Size:
    Tucked in the corner, I think I got parts in the mail today. I'll have to go n check. Hopefully some body mounts n chit
    K201979 likes this.
  8. ALL-OF-IT
    ALL-OF-IT Member
    40
    31
    Jul 2, 2019
    Nebraska
    First Name:
    Adam
    Truck Year:
    Truck Model:
    Engine Size:
    Got the "'Chit-Rado" parts out, mostly. Still need to yank the throttle pedal and tac module and also the brake booster/master cyl and other misc things I might need or stuff I might try to retrofit into "ratchet strap" the squarebody.
    5.3/4L60e 2wd pulled out. need to clean it up and seal it off from the 'chit floating around in the garage.
    Also, got the bed hung up to do some work to and also work on the back half of the chassis. Note: If you do this, don't ask a random chick at the bar to help you find out if hanging your bed from the ceiling will be sturdy enough to do work on.....
  9. ALL-OF-IT
    ALL-OF-IT Member
    40
    31
    Jul 2, 2019
    Nebraska
    First Name:
    Adam
    Truck Year:
    Truck Model:
    Engine Size:
    photo update! dozen poof cans later
  10. ALL-OF-IT
    ALL-OF-IT Member
    40
    31
    Jul 2, 2019
    Nebraska
    First Name:
    Adam
    Truck Year:
    Truck Model:
    Engine Size:
    grindin cuttin patchin weldin. etc etc
  11. ALL-OF-IT
    ALL-OF-IT Member
    40
    31
    Jul 2, 2019
    Nebraska
    First Name:
    Adam
    Truck Year:
    Truck Model:
    Engine Size:
    sittin where its livin. now wires, fuels, tunes, driveshafts yahda yahda
    K201979 likes this.
  12. K201979
    850
    792
    Oct 22, 2018
    Winona, missouri
    First Name:
    Hippie
    Truck Year:
    Truck Model:
    Engine Size:
    350ci
    Lookin great!:waytogo:
  13. Madhorn
    Madhorn Full Access Member
    315
    264
    Jan 16, 2017
    AR-Arkansas
    First Name:
    Ken
    Truck Year:
    Truck Model:
    Engine Size:
    5.3/NV4500/NP205/4:56 gear/35in tires
    Nice!
  14. ALL-OF-IT
    ALL-OF-IT Member
    40
    31
    Jul 2, 2019
    Nebraska
    First Name:
    Adam
    Truck Year:
    Truck Model:
    Engine Size:
    Been busy working on a c10 and its robbed my time to work on a c10. Im very ok with it. But here is a update. Pic of C10 robbing my time followed by C10 sq body parts n 'chits.....
    67 Stepside. 6.0 / 4L80e swap. 454LSX Camshaft. Nitrous Outlet Plate kit. This is his occasional daily, gets driven HARD. Just gave it a new intake, fixed some minor misc things and was tuning it for WOT and added electric fans which i also enabled on the tune so they are temp controlled by ecu. BUT the 12 Bolts Eaton Posi decided to shit its gears... So its at a standstill until he can get parts to me and once that's fixed I will finish the tune.
    81Bart and HotRodPC like this.
  15. HotRodPC
    HotRodPC Administrator Staff Member
    45,242
    5,363
    First Name:
    Truck Year:
    85 K20 LWB / 86 K5
    Truck Model:
    Silverado / Silverado
    Engine Size:
    454 - Turbo 400 - 3.73 350 - 700R4 - 4.10
    This is going to be a great project to watch !!! Thanks for sharing and posting plenty of pics. We love porn !!!
Share This Page
