1980 Heater System Explanation
frwgt350net
California
frank
Can anyone lead me to any type of diagram and or explanation
or link on how the heater system works in a 1980 K10, preferably
starting from the switch on the dash.
Tank6x2
Edmonton Alberta Canada
Kurt
C30
350, TH400.4:10 gears 2WD
There are manuals in this forum somewhere that have everything about these rigs, @bucket @HotRodPC may remember where
For some reason I can't copy and paste a link right now. Grrr.
Anyway, look in the library section of the forum.
75gmck25
Northern Virginia
Bruce
The design also has quite a few differences for A/C vs non A/C trucks. For example, an A/C truck has a large black housing under the hood for the A/C evaporator, while a non A/C truck has a nearly flat firewall on the passenger side.
Craig 85
Nashville, TN
Craig
K30 SRW
454/TH-400/NP205
Here's a few of the diagrams I've saved over the years. I'm not sure which year they are specifically for, but its generally the same.
Craig 85
Nashville, TN
Craig
K30 SRW
454/TH-400/NP205
Here an explanation of the air flow. Air enters the truck at the yellow arrow at the cowl. If you have an A/C truck, there is a plastic flap here that closes 80% of the fresh air flow off when on Max A/C. the air then comes out of the circle (where your fan motor is located) and into the plastic box (on an A/C truck). The air is cooled then it goes into the hole the red arrow is pointing to. Once back in the cab, the air will continue to the vents (dash, floor or defrost). If you were not cooling the air, the heater core is located inside the rectangular hole and would heat the air if needed.
On the A/C cab, when you turn on Max A/C, in addition to closing the cowl flap, the passenger kick panel door opens to recirculate air.
frwgt350net
California
frank
Thank you very much - and have a terrific day
iiixtremeiii
