Branktm
- Feb 13, 2020
- Boise
- Brandon
- K15 Sierra Grande
Just got the Tranny and transfer case back from rebuild. Its a turbo 350 tranny and the heavy 208 transfer case. I also bought a transfer case lowering kit from rough country to go with the lift. But from what i see it just lowers down the crossmember by 4 spacers. The weird think is my cross member has 6 bolts. 4 at bottom to each frame rail, and 2 more on the driver side the goes into the side of the frame. I have checked this forum looking for this cross member, i have seen the ones with 4 bolts, then others that have a bolted on side part like mine. But this is ALL one piece. think of it as an L shape, with the short end bolting up to the side of the frame and the rest under the frame.... Is this common? I cannot see how my transfer case lowering kit is going to work. It will lower it down but the side bolts wont be lined up. Sucks because it just got frame and cross member powder coated. Do i need to get a new crossmember? Is this factory? I am confused.
