1974 K20, SM465 manual,203 transfer case,350 engine…what is the clutch disk size? I’d like to order it before pulling it.
roguewave
Texas Hill Country/South Portland, Maine
Bobert
76,83,84,87,87,88.
4X4
….so I can throw it back together right away.
I’ll buy the whole kit, clutch disk, pressure plate, throw out bearing and pilot bearing. I know it’s best to pull it first bit I need it to go back together quickly.
thanks !
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
It’s 11” IIRC. Though it may accept an 11 or 12”. Someone who knows better could chime in soon.
When in doubt, RockAuto’s parts catalog is pretty darn accurate and their prices are good.
Rickf
Grafton NH
1974, 1954 & a 1937
My '74, 350,SM465, & 203 has a 12" clutch.
thanks !
are you saying you have a sm465 with a np203 currently? Isnt that literally a unicorn?
Turbo4whl
Downingtown, PA
Wayne
Jimmy
are you saying you have a sm465 with a np203 currently? Isn't that literally a unicorn?
Yes, not available in 1973, auto trans only. 1974 and 1975 I believe, just two years. Maybe a few made in 1976. The issue, you could lock up the drive line on dry pavement. I only did it once, learned my lesson.
roguewave
Bobert
76,83,84,87,87,88.
4X4
I only found out after I put new warn manual locking hubs on, no workie. Promptly took em back off.
I'm not sure I follow. Do you mean get the driveline bound up enough to where you couldn't shift anything?
probably bound up where something had to give and it wasnt cheap
Turbo4whl
Downingtown, PA
Wayne
Jimmy
Yes, here's the story: Driving to work in heavy snow. Get to work, the building crew has the parking lot totally clear. Still in Hi Loc, (not think'in) I turn tight into a parking spot. Truck stops, engine stalls. Have twisted up the drive line, can't move either shifter. With an automatic your could just move the shifter into reverse and back out of the lock-up.
I figure I need to get a jack and lift a wheel, but one more try, one foot on the long 4 sp shift lever and push. Got it out of 2nd, then in reverse and back up.
Do you think that if the finicky 203 shifter was out of the equation, it maybe wouldn't be an issue? Like if the 203 had twin sticks?
Turbo4whl
Downingtown, PA
Wayne
Jimmy
Probably, don't know of a problem like this with the 205 and a stick shift.
shake1969
