1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
1974 Crew Cab 4x4 Restoration/Duramax
Discussion in 'Under Construction' started by Adam Moskowitz, Aug 26, 2018.
  1. dvdswan
    dvdswan Full Access Member
    604
    238
    Mar 11, 2014
    Port Orchard, WA
    First Name:
    Dave
    Truck Year:
    Truck Model:
    Engine Size:
    :popcorn::popcorn::popcorn: Hey Mikey, he likes it.
  2. bucket
    bucket Super Moderator Staff Member
    37
    18,230
    3,190
    First Name:
    Truck Year:
    Truck Model:
    Engine Size:
    Do you plan on pulling heavy loads with this rig? Are those fans able to move as much air as the stock clutch fan? I know that while pulling a good load, they can run hot if the fan clutch gets even a little bit weak. I take that as meaning the stock fan is barely adequate.
  3. Adam Moskowitz
    Adam Moskowitz Full Access Member
    83
    102
    Aug 26, 2018
    Southern California
    First Name:
    Adam
    Truck Year:
    Truck Model:
    k30
    Engine Size:
    6.6L Duramax
    As of right now I dont plan on pulling anything beyond 8000 or so lbs..something like a car/truck or a toy hauler. From what I've read the mechanical can pull like 10,000 cfm at full steam. Everything I've seen on these fans says they can do somewhere between 4-6000 cfm each on high. I think I should be ok but if I need to, i may put a 2000cfm aux pusher fan in front of the a/c condenser for towing
    Sent from my SM-G950U using Tapatalk
  4. Old77
    Old77 Super Moderator Staff Member
    24,977
    1,720
    First Name:
    Truck Year:
    1977/1991
    Truck Model:
    C10 longbed/R3500 Dually
    Engine Size:
    350/454
  5. climb-101
    climb-101 Full Access Member
    208
    205
    Mar 12, 2018
    montana
    First Name:
    seth
    Truck Year:
    974
    Truck Model:
    c2 crew cab
    Engine Size:
    6.0 LS
    looks good. hopefully next week or two i’ll be working on radiator and fans in my crew cab build
  6. Adam Moskowitz
    83
    102
    Aug 26, 2018
    Southern California
    First Name:
    Adam
    Truck Year:
    Truck Model:
    k30
    Engine Size:
    6.6L Duramax
    Not many photos but got the 40 gallon suburban tank mounted and modified the sending unit slightly so it should work just fine with the duramax 1/2" feed and 3/8" return. Got my beefy steering arms in from RuffStuff with the Odyssey battery boxes and set the engine harness on the duramax! Working on the fuse box wiring for the engine and then this baby is about ready to fire[​IMG][​IMG][​IMG][​IMG][​IMG]
    Craig 85 and B.K. Cunningham like this.
  7. Adam Moskowitz
    83
    102
    Aug 26, 2018
    Southern California
    First Name:
    Adam
    Truck Year:
    Truck Model:
    k30
    Engine Size:
    6.6L Duramax
    Got the wiring harness done! Just need to wire it to the fuse box and then do the new painless truck harness. Injectors are in and started working on the battery box mounts. Just about ready to fire up! Also got my Diy4x np205 mount in, cant wait to get that set up after it fires off[​IMG][​IMG][​IMG]
  8. Adam Moskowitz
    83
    102
    Aug 26, 2018
    Southern California
    First Name:
    Adam
    Truck Year:
    Truck Model:
    k30
    Engine Size:
    6.6L Duramax
    Got the Ruffstuff battery tray mounted for the first Odyssey battery. Going to make the mount for the ecm, tcm, gpcm, and fuse box tomorrow then wire them up to the battery and make some noise this weekend[​IMG]
    B.K. Cunningham and climb-101 like this.
  9. Adam Moskowitz
    83
    102
    Aug 26, 2018
    Southern California
    First Name:
    Adam
    Truck Year:
    Truck Model:
    k30
    Engine Size:
    6.6L Duramax
    Under hood fuse box done! (Until I add relays for accessories) Fans will be on their own circuit. That means shes gonna get cranked up on saturday![​IMG]
    akchevrolet likes this.
  10. Frankenchevy
    Frankenchevy . Supporting Member
    2,032
    1,332
    Jan 3, 2018
    usa
    First Name:
    Truck Year:
    old
    Truck Model:
    pickup
    Engine Size:
    8 cylinder
    Just saw this thread for the first time. I don’t know how I missed it. Awesome build! Motivates me to sack up and get back on mine...maybe when deer/black bear season ends!
    73c20jim and Adam Moskowitz like this.
  11. dvdswan
    604
    238
    Mar 11, 2014
    Port Orchard, WA
    First Name:
    Dave
    Truck Year:
    Truck Model:
    Engine Size:
    :popcorn: Let us hear this baby roar. . . or purr. Which ever, just want to hear it run!
    Adam Moskowitz likes this.
  12. Adam Moskowitz
    83
    102
    Aug 26, 2018
    Southern California
    First Name:
    Adam
    Truck Year:
    Truck Model:
    k30
    Engine Size:
    6.6L Duramax
    Haha you and me both! Just gotta run the battery cables for both batteries, run the fuel hose from the filter head to cp3, put fresh fluid and filters, and then see if we can make some noise tomorrow. Video going up instantly if it fires haha
    73c20jim likes this.
  13. Adam Moskowitz
    83
    102
    Aug 26, 2018
    Southern California
    First Name:
    Adam
    Truck Year:
    Truck Model:
    k30
    Engine Size:
    6.6L Duramax
    Haha thanks man! Just went through yours and your truck looks great! Get on that thing and take it out hunting with you
    73c20jim and Frankenchevy like this.
  14. Old77
    24,977
    1,720
    First Name:
    Truck Year:
    1977/1991
    Truck Model:
    Engine Size:
    350/454
    Awesome progress! :popcorn:
  15. Adam Moskowitz
    83
    102
    Aug 26, 2018
    Southern California
    First Name:
    Adam
    Truck Year:
    Truck Model:
    k30
    Engine Size:
    6.6L Duramax
    Well...got the battery cables made, filter head hooked up, some misc, flashed the ECM and cranked! (Video attached)
    Forgive the messy wires, wanted to make sure it ran before I loomed everything. Time to pull the harness, clean it all, and start final assembly and get this pig on to daily duty![​IMG][​IMG]http://cloud.tapatalk.com/s/5bc3ef503dc08/VID_31190528_181215_120.mp4
Share This Page
