1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
1974 Crew Cab 4x4 Restoration/Duramax
Discussion in 'Under Construction' started by Adam Moskowitz, Aug 26, 2018.
  1. Adam Moskowitz
    Adam Moskowitz Full Access Member
    83
    100
    Aug 26, 2018
    Southern California
    First Name:
    Adam
    Truck Year:
    Truck Model:
    k30
    Engine Size:
    6.6L Duramax
    Got the knuckles hung on the Dana 60 since I had some time this morning. Heres a shot of the engine crossmember I did..not really happy with it so I'll probably remake it but it's holding for now
    20180903_131001.jpg 20180903_141539.jpg 20180903_141544.jpg 20180903_114010.jpg
  2. bucket
    bucket Super Moderator Staff Member
    37
    17,953
    2,988
    First Name:
    Truck Year:
    Truck Model:
    Engine Size:
    Are those the stock 2wd engine mount brackets, or are they from a K truck? I think one style is shorter, but I don't remember which.
  3. Adam Moskowitz
    83
    100
    Aug 26, 2018
    Southern California
    First Name:
    Adam
    Truck Year:
    Truck Model:
    k30
    Engine Size:
    6.6L Duramax
    They are the factory 2wd upper mount and the 2wd engine mounts from Precision Fab Plus
  4. Adam Moskowitz
    83
    100
    Aug 26, 2018
    Southern California
    First Name:
    Adam
    Truck Year:
    Truck Model:
    k30
    Engine Size:
    6.6L Duramax
    Got the axles ground down to put the full circle snap rings on the new Spicer u joints. Next to install spindles, big brake caliper brackets, and hubs
  5. Adam Moskowitz
    83
    100
    Aug 26, 2018
    Southern California
    First Name:
    Adam
    Truck Year:
    Truck Model:
    k30
    Engine Size:
    6.6L Duramax
    Got the tracking and I'll have the front leaf springs Thursday which means this thing is getting the dana 60 shoved in Saturday and she'll be a roller! Got the spindles together and big brake calipers on. Started putting the front hubs together, still need to grind them down to clearance these HUGE brakes going on, then stab these, the Warn hubs, and we have an axle haha 20180910_194217.jpg 20180910_191243.jpg
  6. Adam Moskowitz
    83
    100
    Aug 26, 2018
    Southern California
    First Name:
    Adam
    Truck Year:
    Truck Model:
    k30
    Engine Size:
    6.6L Duramax
    Well, got the hubs back from the machine shop. Had to have the outside turned down a little for the big brake upgrade with brackets from Torq. Will be using front brakes off a 2011+ ram 3500 which are MUCH larger that what would have come on this thing. All new hardware throughout, all new bearings, seals, etc and finally put the new Warn hubs on tonight. This baby is ready to go home!
    B.K. Cunningham likes this.
  7. Adam Moskowitz
    83
    100
    Aug 26, 2018
    Southern California
    First Name:
    Adam
    Truck Year:
    Truck Model:
    k30
    Engine Size:
    6.6L Duramax
    Almost forgot! Beautiful new spring packs came in today from Offroad Design and Alcan Springs..excited to get the front axle under and mounted on Saturday to make this thing a roller again! 20180913_204231.jpg
  8. bucket
    37
    17,953
    2,988
    First Name:
    Truck Year:
    Truck Model:
    Engine Size:
    Where's the best place to buy that brake kit from?
    Was there a reason for having the hubs turned instead of just opening up the rotors?
  9. dvdswan
    dvdswan Full Access Member
    578
    233
    Mar 11, 2014
    Port Orchard, WA
    First Name:
    Dave
    Truck Year:
    Truck Model:
    Engine Size:
    Coming along nicely. :popcorn:
  10. climb-101
    climb-101 Full Access Member
    190
    184
    Mar 12, 2018
    montana
    First Name:
    seth
    Truck Year:
    974
    Truck Model:
    c2 crew cab
    Engine Size:
    6.0 LS
    im interested in the brake setup also, where did you get the brackets and stuff from
  11. Lostranger
    Lostranger Full Access Member
    65
    54
    18
    Jul 16, 2013
    Marion, NC
    First Name:
    Truck Year:
    Truck Model:
    R30
    Engine Size:
    Loving this build. Always nice to see how the "other half" builds stuff.
  12. Adam Moskowitz
    83
    100
    Aug 26, 2018
    Southern California
    First Name:
    Adam
    Truck Year:
    Truck Model:
    k30
    Engine Size:
    6.6L Duramax
    http://www.torqmotorsports.com/Big-Brake-Kit_c_157.html
    Here's a link to the brake kit. You can either buy just the brackets or buy the whole brake upgrade. Reason I did the hubs not brakes is that if I was to do the brake hat, it would be much more material to remove vs. just shaving the lip on the hub down a bit and when I need rotors again, I won't need to have them remachined; just remove the old and install the new
    Thanks! Still a ways to go but it's nice to see it starting to take shape. What's this "other half"? haha
  13. Adam Moskowitz
    83
    100
    Aug 26, 2018
    Southern California
    First Name:
    Adam
    Truck Year:
    Truck Model:
    k30
    Engine Size:
    6.6L Duramax
    As promised...shes on her own wheels! Dana 60 tucked nicely under there. Got a wrong pair of bushings so its snug but loose still but it's all under there, officially a 4wd now and a roller again! 20180915_143822.jpg 20180915_165221.jpg 20180915_165224.jpg 20180915_181105.jpg 20180915_181114.jpg
    73c20jim, bucket and climb-101 like this.
  14. Adam Moskowitz
    83
    100
    Aug 26, 2018
    Southern California
    First Name:
    Adam
    Truck Year:
    Truck Model:
    k30
    Engine Size:
    6.6L Duramax
    Looking more and more like a truck. Got the new bed and tailgate on, rolled it out of its hole for a little since it's a roller finally 20180916_172028.jpg 20180916_172022.jpg 20180916_172039.jpg 20180916_164011.jpg
    Old77, 73c20jim, Craig 85 and 3 others like this.
  15. Adam Moskowitz
    83
    100
    Aug 26, 2018
    Southern California
    First Name:
    Adam
    Truck Year:
    Truck Model:
    k30
    Engine Size:
    6.6L Duramax
    Got my taurus fans in today so I set them in after work...they're gonna fit! Started trimming the shrouds and making brackets for them 20180919_134118.jpg 20180919_181504.jpg
Share This Page
