14 bolt posi swap
Cooterbfd
Bristol RI
C-20 Custom Deluxe
Got a simple question. I have a 10.5" 14 bolt open axle in my '79 C-20. Would I be able to put the pinion and carrier from a newer ('01-06 ish) unit, or are they totally different beasts.
Thanks, John
TubeTruck
East TN
Denis
Suburban K10
LQ9
I believe they are the same. I know the pinion bearings are bigger on the newer ones but not sure if that includes the I.D. if the bearing or just the O.D.
Cooterbfd
Bristol RI
C-20 Custom Deluxe
Thanks.....but if I can buy a 3.73 ring and pinion for my rear and bolt it to the newer carrier, that wouldn't be an issue, right?
Loco Hills
K-30
I had trouble with this same situation.I could never get the external pinion shims right.
The pinion depth was way off,pattern to.I had gotten a used ring and pinion from a newer 14 bolt (big bearing) along with the pinion bearing housing.Trying to save some coin.Ended up doing a full rebuild,older bearing housing and a new ring and pinion...Went together like magic,perfect.
Maybe you’ll have better luck
Cooterbfd
Bristol RI
C-20 Custom Deluxe
Do you think a new ring and pinion for an old 14 bolt would bolt up to the newer version carrier???
Loco Hills
K-30
Try it,if it doesn’t work,see if you can find a pinion bearing housing from an older model 14 bolt.I honestly think it’ll save you some grief.You’ll only be out the big bearing.The other pinion bearing is the same.I believe the pinion seal was different as well.However,I was able to use the newer yoke.They put a removable sleeve on it to account for the big bearing.I saw some older model bearing housings on eBay not that long ago
Loco Hills
K-30
And yes the ring gear will bolt up to a newer carrier
Cooterbfd
Bristol RI
C-20 Custom Deluxe
Thanks. For a $100 I'm going to take a kick at the cat.
Linemanjl
