1 inch bolts on a SB Chevy?
82Diesel
I <3 a gutless greasy diesel
SW, MI
Kyle
Silverado K10
6.2L
It has been awhile since i worked on my 82 K10... For Christmas i might gift myself a 1" socket set. I forgot... is there a lot on these trucks?... and what locations? i.e frame, any cross-members, maybe axles, or suspension.
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Balljoint nuts maybe...?
Spindle nut?
Pinion nut?
Crank bolt?
Alternator nut?
Theres not but a few things
82Diesel
SW, MI
Kyle
Silverado K10
6.2L
Spindle nut?
Pinion nut?
Crank bolt?
Alternator nut?
Sorry, I forgot. I was most curious about the frame, any cross-members, maybe axles, or suspension.
legopnuematic
Licensed Junk Dealer
MO
Spencer
A 1" socket or a 1" drive socket set?
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
7/8 is pretty much the biggest on these trucks. Balljoints may be an inch but I can't remember now.
Nothing else is bigger. Maybe a pitman arm nut. U bolt nuts are 15/16 most of the time.
Moodyalaskan
Chugiak, Alaska
Walter
Worked as a mechanic for over 40 years. Only time ever needed a 1" drive set was for heavy equipment and 5 ton thru tractor trailers. I'm good with a 3/4 drive set with a 3/4 to 1" adapter. I would rather buy a quality 3/4 impact first and 1" drive socket size I needed than a complete 1" set.
1” is fairly common for fittings on some plumbing or hydronic systems, but usually you need an open end wrench.
I had to use a 1 1/8” open end just last week to hold the fitting while I tightened up a gas line on a duel-fuel range. I don’t remember when I bought that odd size open end wrench, but it was probably for some other plumbing task.
idahovette
Firefighter
Weiser Idaho
Perry
K20-K10
1 1/8 combination wrench not uncommon in my old profession.....Alignment. A lot of old, 65-70 GM products, used strut rods(brake reaction rods) for the front suspension that had those large nuts on the rod and were used to set caster. Open end used on the backside and closed end on the front.
Fat 454
Australia
C20 Suburban
spend the money on a good quality ( dewalt / milwaukee ) 1/2" drive cordless impact wrench. With a set of 1/2" 6 sided impact sockets that will remove anything you are working on for a c/k truck. You will ask yourself why you didn't do this sooner ..
that_orange_c10
