Window crank handle replacement
hey mister
North Coast
Marty
Good Monday to all...
Yesterday the driver's window crank gave up...fortunately the window was and is up.
Figured I'd just go to the local self serve scrap yard and pop a couple off and everything would be ok. Found a couple and wagged them home.
Well, that was a flop....but most of you had already guessed that...hadn't you?
Yea...funny...
I'm sure I ain't the first to do this, so...what non-stock replacement cranks have you bought and either hate or love?
Thanks for the input, guys.
BTW, ...the "shop rag between crank and door panel" trick to get the crank clip out, is freaking slick.
Y'all have a great day.
Edelbrock
Earth
Grumba
K5 Blazer
My rig had problems with both windows. One side was super hard to roll up and down, and the other side would get jammed and was just all around crappy. Didn't have to replace any parts. Just had to take them apart, lube everything, and make a bunch of adjustments. It took a long time to get them to work right, but once I finally did - they both work great.
hey mister
North Coast
Marty
I found die cast, chrome plated cranks for $12 each at Summit Racing.
markgsp
