305_Square_Body
- Mar 27, 2023
- Richmond, VA
- Andrew
- R10
Ok, I have a new spark plugs, a new map sensor, a new fuel filter, and a new coolant temperature sensor. 1987 R10 Silverado With a 305 engine. It is running very rich and none of the above fixes has changed anything. In fact, I can’t really get it to run it wants to cut off. The throttlebody appears to be in decent shape. The fuel Injectors are spraying. Where do I go from here?
