Electric choke on Holley carb.
Mikehell666
USA
Michael
I put a Holley carb in and it ran fine for awhile and the electric choke failed, I installed a new one and after running for 5 minutes or so it won't open up and stalls the engine. I have the wiring correct keyed power and a solid ground, Ive tried adjusting the choke but it doesn't make any difference. I made a huge mistake in buying a Holley (I don't like quadrajunk) but now that I'm stuck with it I have to fix it.
fast 99
Spokane, Washington
If 12 volts are at the choke thermostat it will open. Does it have power running? Is the ground intact?
Although I think Q jets run better on a GM a new Holley should be ok.
Turbo4whl
Downingtown, PA
Wayne
Do you have 12 volts at the choke wire after the engine starts? Did the carb you removed have an electric choke?
potent rodent
indiana
butch
86 and 78
350 and 305
make sure u have 12 volts to the + side of the choke use a test light or better a volt meter, make sure u have + to+ and neg to neg
iiixtremeiii
