bbusse
- Mar 8, 2023
- USA
- Brian
- K10
I know, I know, reset the timer for number of minutes since someone asked the same question.
I’m getting used to forums again, been spending too much time on Facebook groups these days and using my phone of course which makes it even easier
I have, currently, a 1973 bone stock K10. I am about to install a rough country 2 inch lift kit, not using blocks. The truck currently has what I always referred to as white generic trailer wheels And I of course put new tires on it last March when we revived it.
That said, I want to purchase similar wheels because I actually like the look, that are 15x8. And then get some Goodyear DuraTrac tires that are 33X12.5X15.
If nothing else on the truck has been replaced/modified, is there any reason whatsoever that I should not be able to do that as long as the backspacing on the wheels is 3.75 inches?
I have attached a couple pictures of what I was looking at. Far as I can tell, it looks correct although their website doesn’t list anything as fitting this truck. So I’ll have to call in the order, but that means I need to be extra sure what I order is valid.
Thoughts?
Thoughts?
