Hydro boost
wayfastwhitey575
Cyrl
350 vortec
What models are good donors to acquire a hydro boost?
bluex
Spartanburg SC
C15
Usually any truck with a diesel engine, 1 tons, ASTRO vans. 98-04 mustangs had it too.
fast 99
Spokane, Washington
There are internal, hose fitting differences and possibly different design [length and style] pushrods. If this is a conversion main thing would be the pushrod.
The base GM brakes are a good design with decent assist. Personally, wouldn't poke the bear adding Hydro boost. Adds complexity and numerous places for leaks.
AKguy
Alaska
Randy
K30 Crew Cab Silverado
I took mine off a 1980 1 Ton for my 1981 C20. Used the rod that was in the donor unit.
Hunter79764
Grand Prairie, TX
Suburban V20
I have an '04 Yukon Denali with Hydroboost, I planned on swapping onto my '87 unless someone has good reason why those wouldn't be good donors. I think Escalades of a similar year had it too, but my '13 Denali has conventional vac system.
TPISly-C10
Boucherville QC Canada
Sly
C-10 shortbox
LQ4 6.0L
i use 1999 Sierra 2500 master, 1999 S10 reservoir (no sensor more oil), 2003 HD hydro, OEM C10 HD hoses... to upgrade my ugly iron OEM kit! :)
TubeTruck
East TN
Denis
Suburban K10
LQ9
Check out my build on page 11. I tried adapting a few different hydraboosts. I settled on one out of a 2001+ and the corresponding master.
rossivey
