Speedometer Cable
custodian
Catawba
William
5.3 LS, 350
Is 80" the correct length for the speedometer cable for an 85 C10 350/700r4 2wd?
Tank6x2
Edmonton Alberta Canada
Kurt
C30
350, TH400.4:10 gears 2WD
Can you pull the other one if it needs to be swapped anyway and measure it?
WFO
Texas Panhandle
You can measure them with a measuring tape while still installed.
Crawl under the dash and measure from the Speedometer to the firewall along the route of the cable, then get under the truck and measure from the firewall, following the route of the cable, to the other end of the cable.
Mickey1977
