bigcountry78
- Apr 16, 2013
- Hickory, North Carolina
- James
- K10 Custom Deluxe
I spent the better part of the afternoon putting a 2500 pound winch on my 6x12 utility trailer. Got the winch and switch mounted, now I’m trying to figure out the power situation. Short term fix is to grab the battery out of my square and just use that, but I’d like a longer term better solution. So, is there a way to power a small winch from a 7 way plug on a truck? I know the center pin is normally used to charge a camper battery, but does anyone know if that’s sufficient to run a winch off of? I could also run my own wire to the back of the truck, but if I can use what’s already there, naturally that would be easier.
Also, if charging a trailer battery from the truck is a better option, I can go that way too. I already have a toolbox on the tounge that I can mount a battery in.
