Part identification
Viper75x
USA
K10 stepside
Can someone tell me what part this is? See pic. The piece between the pipes and behind the wire. That little metal stub thingy.
Viper75x
USA
K10 stepside
Idiot light, lol. Thanks guys
Viper75x
USA
K10 stepside
How about this thing? Next to the distributor.
Viper75x
USA
K10 stepside
Yeah a lot of stuff is missing. See the vacuum lines? They're capped and not sure where they're supposed to go. Can't see the choke very well but it's missing a piece as well. I bought a used qjet from a local guy but it was not the same model so i could only use the choke blade and one linkage off of it
Google an Emissions sticker for your engine.
Radiohead
Reducing tire diameter 1000 revolutions at once
Low Earth Orbit
MCMLXXIX
C-20 Silverado Camper Special
I read that and said challenge accepted.
It works!
Unless you have a '79 big block with CA emissions. Just my luck.
Viper75x
USA
K10 stepside
Lol
fast 99
Spokane, Washington
Behind the cruise control servo is an oil pressure sender. It is not hooked up. There might be 2 switches on a single Y fitting. If equipped other one would be for choke thermostat preheat power. That circuit closes after oil pressure is achieved.
Laqota
