Vortec heads spark plugs and dieseling
Foursightho
North Carolina
Elijah
In need of some help. Just got my rebuilt motor back from builder. I asked the builder for two things for my build 1) vortec heads on my original 85 block and 2) to be able to run pump gas 87 octane.
Got the motor up, broke in, and running but plugs are real black and sooty. Also engine is dieseling with 87 octane gas.
Any advice on what to do to help run regular gas? Also do I need to use the later model spark plugs for the vortec heads (mine came off a 98 Yukon he said) or can I use the shorter plugs that were factory for 1985?
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
Did you confirm if it still does it with high octane fuel?
TBI or EFI would probably eliminate dieseling, not an easy remedy though.
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
64cc chambers on a sbc are pretty small, what piston did he use and what deck height ?
Foursightho
North Carolina
Elijah
It doesn't do it with 93. I really would like to add efi but that another 2k at least.
77 K20
Montana
K20 5" lift
HT383 fuel injected
Not sure if this helps or not but on the GM crate engine I bought with vortec heads (HT383) they said to set timing to 10 degrees BTDC at 650 RPM with the vacuum advance line to the distributor disconnected and plugged. They want 32 degrees of total advance when using HEI distributor P/N 93440806 (at 4,000 RPM). The HEI vacuum advance canister should remain disconnected.
This engine was 9.1:1 compression. Designed to run on 87 octane.
Spark plugs: R44LTS gapped at .040"
But I don't know what cam you are running or know what carb you are running.
fast 99
Spokane, Washington
Assuming a carb? If yes, does it idle slow enough? If automatic shut it off in gear.
Plugs should never be black. Too much fuel?
87 octane is low. Try 91 or whatever is available.
Do not allow the dieseling to continue. Immediate engine damage can occur.
Foursightho
North Carolina
Elijah
I'm running an Edelbrock 1406 600 cfm carb. I don't have the lts plug in using my original plugs maybe that could be part of my issue
Foursightho
North Carolina
Elijah
I don't know how to fix the rich carb. Is it just the idle screws or Do I get a larger carb with more cfm. Right now I got a 600 should I get a 650 or 700? Do I need to jet the carb.
fast 99
Spokane, Washington
600 is fine, need to know what brand carb. We can help you through it provided you have basic knowledge. There should be u tube videos as well.
Running a new motor rich and dieseling is a recipe for disaster.
QBuff02
Central IL
Quincy
my money is on checking and verifying the timing first. What was the condition of the distributor that you put in the engine? Black and sooty plugs is an obvious rich condition. Could be as simple as tuning the carb and making sure the timing is right for the engine. What was the cam that was installed in the engine?
kmousseau8
