- Aug 3, 2010
- Usually not in Ohio
- Andy
- '77, '78, '79, '84, '88
- K5 thru K30
I also installed some springs from the hardware store on the hood hinges. I removed the originals years ago because they were too much for the fiberglass hood and they were causing it to bow. I still need a prop rod with the new springs, but it's so much easier to lift open.
Now I'm changing the rear diff fluid, replacing the header gaskets and cleaning the idle circuit on that damned Edelbrock carb. The idle circuit has been an intermittent problem for the last 10 years. Stupid Edelbrock carb, lol @78C10BigTen
