Matt69olds
- Jan 8, 2018
- Central Indiana
- Matt
- GMC 1/2 ton
- 455 Olds
This 92 Yukon rear end is REALLY starting to piss me off!!!
Trying to replace a rear axle seal. Pretty straightforward (I thought) something I have done dozens of times before.
Unfortunately, the cross pin bolt broke. I’m almost 50 years old, been fooling around with cars and trucks since I was 15, first time I have ever broken one of those bolts. I bought the tool kit to extract it (nothing more than a really long drill bit, a drill guide bolt, and a couple extractors) 20 minutes later the broken bolt is out. Removing the cross bolt was easy.
Now, the next hurdle. The C-Clip REFUSES to come off the axle!!!! Usually, just pushing the axle in causes the C-clip to fall off, requiring you to fish around in nasty gear lube to find it. Not this rearend!!! The C-clip is free to spin in the retaining groove, the axle moves on and out freely, and there is actually a little slop for the C-clip to wobble on the axle. It flat out will not come off!!! I even fabricated a tool with fingers to push the clip off, thinking the clip or axle is mushroomed, no luck.
At this point, I’m obviously overlooking something. I have never owned a vehicle with this style carrier, is there a special procedure or step I’m missing?
