CheemsK1500
- Jun 3, 2022
- Texas
- Paul
- K1500
The answer is most times obvious, cost, ease of assembly and engineering requirements ie safety.
Never liked any under dash work but it is part of the automotive "experience".
Today no one wants to get out and turn in hubs. All that fancy stuff eventually fails then,,,,,,,,,,,,,, shocker it is expensive to fix.
One of the most infuriating jobs I did was fixing the push button 4x4 system on a 2004 2500HD. after much trial and error, I narrowed the issue down to the control module tucked behind the dash. After installing the new module, it still wasn't fixed.
I had a GM technician investigate. It turns out that the parts supplier messed up and sent me a module for an AWD Avalanche. He reprogrammed it to work with the 4wd pickup, and now it's good as new. The modules aren't labeled on the outside and all use the same style connector, so you are pretty much just putting good faith in the parts supplier to send the correct module.
