iamtherealJayy
- Nov 26, 2021
- Tennessee
- Jacob
- 1987, 1978, 1976
- V20, K10, K10
Also when taking off on slight incline or level ground the truck shutters taking off, similar to what I’ve heard semi drivers say when they’re pulling heavy loads. If I give it more throttle it does fine but at that point I’m really slipping the clutch. It’s only from a complete stop taking off. I try to stay around 1200rpms taking off but I usually get up to 1700/1800 before the truck is really moving. I need to adjust the clutch pedal to be farther down I believe. Although sometimes I can’t pull it out of reverse and I have to think for a second and then pull it out of gear. My personal preference is the clutch grabbing soon, if not right as you, after letting off pedal. I adjusted the clutch in the “z bar?” Linkage I believe it’s called? But I reverted my changes due to I overdid it and I could hardly drive the truck. An 87 with 3.42 and hydraulic clutch is way different than a 78 with mechanical clutch and who knows what rear end ratio.
