Matt69olds
- Jan 8, 2018
- Central Indiana
- Matt
- GMC 1/2 ton
- 455 Olds
I have been searching for a intermittent misfire on my 92 Yukon. Occasionally, the #1 injector (the on on the passenger side) won’t pulse. No injector pulse, swapping injector plugs and the problem follows the connector.
Make a long story short, the dark blue wire (#1 ground) terminal was push out the back of the ECM connector. No connection, no ground, no injector pulse. Now, my problem:where did that wire go?!
I found a diagram online, it said dark blue injector ground goes in connector C, pin 16. Only problem, that cavity is already occupied. So obviously the diagram I have is incorrect.
