Matt69olds
- Jan 8, 2018
- Central Indiana
- Matt
- GMC 1/2 ton
- 455 Olds
Start with the basics. Remove the air cleaner. With the engine completely cold, floor the throttle. Make sure the choke fully closes. Start the engine, the choke plate should open just a little as soon as it starts. If not, you may have defective choke pull off, or it may need adjusted. As the engine warms, the choke plate should open more, until it’s eventually open all the way. Fast idle speed should be around 1200-1400 rpm. Once the engine is warmed up, a tap on the throttle should disengage the fast idle.
