shinkle
- Apr 10, 2021
- AL
- Barry
- R10
I have 87 R10 with 4 headlight set up. Running lights/turn signals in the grille and running lights/turn signal on the outter front panels. The 2 upper lights are the dim and the 2 lower lights are high beams. All 4 are on when high beams are selected but only the top 2 when dim is selected. My issue:
Randomly my passenger turn signal arrow on the dash will glow greeen. When I turn the signal on it blinks really slow. Bigger problem is the passenger upper dim headlight goes out. Then out of no where the driver side upper will go out. Occassionaly no dim lights at all. If I turn on high beams all 4 lights work great. I never have any issue with the lower 2 high beam lights, turn signals in the grille or on the outter front panels. Only intermittent on off upper dim lights and the weird arrow glow slow blinker.
