Does anyone sell a front to back dual exhaust system for a 82 K10?
t44e6
NH USA
I would like to buy a complete exhaust system for my 82 K10 with a 350 / 4 speed to connect to the stock manifolds. Does anyone offer one? I know they are offered for many different kinds of cars.
DanMcG
Central NY
k10 k10
I got my complete 2 1/4” system from Summit, and it was Flowtech 52525FLT. I used Magnaflow 11225 mufflers. I also used a Summit SUM- 642022 balance pipe, but that’s not required. I bought two extra hangars and some clamps locally to keep it supported better (I think it came with 4 hangars).
If you use the balance pipe you have to shorten the intermediate pipes to allow for the extra length, and you end up with a lot of clamps. Welding would make it cleaner, but I don’t have one.
AFAIK, nobody makes a 2 1/2” system off-the-shelf at a reasonable price for the 4x4 trucks.
Ken B
indiana
ken
Following ....but need it for 2wd
RoryH19
Rory
R10 Silverado SWB
Agreed, I don't recall finding any kits for my k5 that are 2.5" true duals.
I built mine, headers, cats, mufflers, h-pipe, and tips. Used magnaflow cost 1k after installation.
All the 2 1/4” exhaust systems I’ve seen online (LMC, Summit, etc.) for squarebody trucks will fit both 2WD or 4WD trucks. Pypes exhaust makes a 2 1/2” system (for about $1,100) for 2WD trucks, and in the notes they say it could be modified to work around a 4WD transfer case. However, there isn’t much clearance, so YMMV.
The Flotech manifold back system is about $200, and then you need two mufflers that will cost from about $40 on up to $140 each. I used the Magnaflow mufflers, which run about $100 each.
Dynamic makes a dual kit for manifolds too.
Several years ago I found a part # for a Hooker 2.5" kit. It was priced significantly higher than the standard 2.25" kit. I don't remember the part number, or even the name of the kit (Super Comp maybe), but it did at least exist at one time.
RoryH19
Rory
R10 Silverado SWB
That would have been nice to have. I had to go with a builders kit and then add mufflers and cats.
RNFL
