- Oct 30, 2019
- Downingtown, PA
- Wayne
- Jimmy
Be sure to check the fit of the shaft in the pump bushing. If there is any side to side or up and down movement, that is what will make the front seal leak. The bushing is pressed in the pump housing and it does not usually come with the reseal kit.My power steering pump has been leaking like a sieve so I'm going to try to rebuild it. This will be a first for me. Fingers crossed.
