Rear Wheel is Stuck !!
81squared
Pawling NY
Marc
scottsdale
Spent the last 3 hours sweating my face off trying to remove a stuck wheel. the other 3 came off no problem, rear driver... not so much
can of liquid wrench....check
Beat rim for hours....check
Drove short distance with lugs loose ..... check
Said a few four letter words in front of my daughter .... check
Pryed and beat some more .... check
you get the point lol
are there any secrets of tricks... I used a 5 lb sledge, i dont have a bigger one... yet
PrairieDrifter
North Dakota
Mason
350, 350, 350, 350, 350
Heat is your best friend, even a butane torch could help if you sit there long enough. An air hammer would probably be the next tool I went with.
Pic of the wheel please. No joke.
Jawzjeep
Honk if parts fall off
Washington
Joshua
Suburban
My advice is to walk away and let a friend try. Dont look at what he's doing. You probably dont want to know.
I'd have issues sometimes like that and call the old man to help. He usually sent me away for a second to take care of whatever it was. I finally asked him why one day and he said, "I ain't afraid to break it like you are!"
Dad's. Lol
But seriously. Try a big 3 jaw puller if you can fit the jaws through the wheel. I had to do it on my jeepster. Put a piece of scrap on the flange on the end of the axle and stick the teeth through the white spoke rim. The rim is no more I'm afraid. Keep in mind safety precautions that's a lot of force that can really only go one way.
K. I'd see if I could cross a chain from 1 cut out at say 9 and across to 3 press the base of a bottle jack against the chain the post against the axle put some steady pressure to it then whack the back side of the wheel.
PrairieDrifter
North Dakota
Mason
Really expected to see something more corroded.
Those threads for the center caps any good? Push a bolt through there, see if it pops.
That's what I would try. I'm guessing the paint is holding it on, the almost friction fit and wet paint.
SirRobyn0
Rob
When I worked at chain tire stores. We had a 10LB sledge for wheels that were really stuck. We'd put them up on the hoist, let the air out of the tire and one or two good hard whacks would get it off. Please if you are going to hit the wheel hard, let the air out of the tire, if you were to rupture the wheel or bead it could kill you. When I was with Goodyear we had to have a guy hauled off to the hospital after the inner tire of a dually blew as he was filling it. Nothing hit him but the air or sound wave gave him a concussion.
78C10BigTen
pennsylvannia
C10 BIG TEN
I work in a scrap yard and process cars, we take off aluminum wheels and some times steels. Ive had many cars that i remove all lug nuts, smash them with the 20lb sledge, even pick them up and drop them them with the CAT loader and they still wont come off! Set them on the ground with no lug nuts and slam into the wheel with the loader forks and they still dont come off. Worse comes to worse they get flipped upside down and our sennebogan 835 gets to remove them with the claw.
Raider L
Shreveport, LA
William
Ha, ha,ha,! I have never heard of any such thing! Really?? It was stuck? Now I've had the same problem with brake drums being stuck but never a wheel. @78C10BigTen, what in the world had hold of them that they would be stuck like that?? Maybe one of the bolts was bent or two, or something like that, but there's nothing other than the bolt threads to get stuck to. What could it have been? I can't see there being that much rust holding the wheel unless it had been under water or something like that.
@81squared, looking at the back of the rim, what did you see?? Was there something evident holding the rim on there? I want to see a picture of it! Did you find one side of the bolts have threads raked off of it??
Corvette Ed
East Tennessee
Eli
I’ve had this problem several times over the years.Take a flapper wheel and clean up the center hole in the rim and the center of the hub lip that makes contact with the hole.
Scott91370
Burleson, Tx
Scott
Sierra1500
In places where this tends to happen take a little wheel bearing grease and put it on the face of the drum/rotor. Just a very thin layer.
RNFL
