- Apr 11, 2017
- kansas
- Rick
- c20
Okay now that you're paying attention instead of arguing. Still 1st thing is check pressure and volume. 2nd the qjet you have is going to have to go away. All qjets are not the same, not even close, and you will not be able to make it work right on your 305. I could but it is a process. You need a qjet for (your) 305 or as close as possible by year and options. Or go with a more universal carb like a Holley. 3rd when we get the fuel and carb worked out you're going to have to learn about timing and yours is going to be rough .Do you still have your ESC distributor laying around? If so it will make your life much easier.
