- May 18, 2020
- Washington
- Todd
- K20
and noted all the white wires join up above the E/brake assembly. Also there is a possibility of interaction between the mechanical movement of E/brake and the wiring in this area..
That’s good to know, thank you.
Not as much visibility under my dash without removing AC ducts. I hadn’t seen that.
