Raider L
- Sep 1, 2020
- Shreveport, LA
- William
- C10
Tuesday I finally got in my leaf spring bushing set I have been waiting on. I originally ordered the wrong size. I found my original receit that was when I had the suspension rebuilt. That way I could see the size I needed for the size leaf spring I have on my truck. So if anyone is needing leaf spring poly bushings for their truck, I guess '73-'80, although the one's for my truck are for the 4x4 leaf springs, 1 1/2" eye.
This is the part number.
This is what you get in one set, enough to do both sides, each eye on each end of the spring, and the shackle links. If you go to the Energy Suspension site it's....difficult to say the least to come up with the exact set of bushings for you truck. On the site there are leaf spring bushings sets for '73 to '74 trucks, but it's a little different number for '73 - '80 trucks. That's why I usually call them. They are very helpful. Then you take the number they give you and go to Summit and get the one's you need. I don't think you can buy straight from Energy Suspension. I should know since I've bought so much from them, but it slips my mind if you can buy from them right now.
