82sbshortbed
Fuckemall!!
- Mar 1, 2018
- SE Texas
- Doug
- 1500 shortbed, 1500 longbed
Started on getting the ring gear assembly out today. That bastard was not moving at all. Tried pry bars and still wasn't moving. So I went to go get something for lunch. Buddy that helped me last week texted me while in line for food. Asked how's it going? Told him what was going on with it. He said text me when you get back at it and I'll come show you a trick. OK great.
He comes over and says gimme a rag and you get a big screw driver. I put it in neutral and turned the driveshaft while he fed the rag in between the ring and pinion gears. It got tuff to turn (hence the big screwdriver) but, it forced the ring gear assembly out. Lol
Then pulled the pinion gear out. Found the third piece of broken gear then.
Need to get it cleaned out and ready for new rear end. Also need the replace my u joints while I'm at it.
